1980 fuse box picture/diagram
Discussion in 'Troubleshooting & Diagnosis' started by JD Z, Aug 25, 2017.
  1. JD Z
    JD Z Veteran Member
    looking to see if folks have a picture or diagram of the 1980 z28 fuse box. I have a blue wire not connected to the fuse box. It's just hanging there. Who knows it might be from some modification over the years. I haven't identified anything besides the wiper pump not working so far.
    Just getting familiar with this old girl. Thanks all!
  2. Twisted_Metal
    26,128
    553
    Where does the other end of the blue wire lead to?
  3. Twisted_Metal
    26,128
    553
    Does it have any type of connector on the end?
  4. PalmbchZ28
    PalmbchZ28 Veteran Member Gold Member
    735
    317
    Jan 29, 2017
    West Palm Beach Fl
  5. PalmbchZ28
    735
    317
    Jan 29, 2017
    West Palm Beach Fl
    Jdz if you PM me your email address I will send you clear copies I have to reduce them so much to upload the file they lose resolution
  6. JD Z
    JD Z Veteran Member
    Thanks guys. I sent an IM PalmbchZ28. A picture of my box with the loose blue wire if it helps Twisted-Metal.
  7. Twisted_Metal
    26,128
    553
    I don't think that's a factory wire.
    It appears to have a male tab to plug in to an accessory, battery or ignition slot in the middle of the fuse block.
    Trace it to see where it goes.
    JD Z likes this.
  8. JD Z
    JD Z Veteran Member
    A quick look and not easy to see where it leads. Didn't look like 30 year old factory wire to me either. I wonder what in the world would need an aftermarket power source? Seems pretty close to factory everything on the car. The motor has been updated with a Holley carb.
    Nothing other than backup lights and license plate lights seem to be an issue that I can see just yet.
  9. Twisted_Metal
    26,128
    553
    It might have had an Electric choke at one time.
    Really hard to say what it was for without seeing where it leads.
  10. JD Z
    JD Z Veteran Member
    Twisted-metal. I traced the blue wire. The updated radio cassette player looks like where it is coming from. Updated maybe in 1985 from the looks of the radio (no brand). It has two wires coming to the fuse box. One is connected with the same connector type and this one is loose. No worries for the car I guess. The radio sounds cruddy. Not sure what that other power source would do for it.
    Thanks for the reply.
