1979 Z28 15" YJ8 TURBINE WHEELS
Discussion in '1978 - 1981 Specific' started by seventy7camaro, Feb 7, 2018.
  1. seventy7camaro
    seventy7camaro Veteran Member Lifetime Gold Member
    I've got my set of YJ8 (N90) turbine wheels being restored and the shop called and said they cannot find a newer reference to the 14P textured bright silver paint needed for this wheel. The assembly manual also shows WA8150 (water based) Has someone here got a definitive match for the paint to do my wheels? If you've got the code(s), let me know asap so I can pass it along to the shop doing my wheels.
  2. seventy7camaro
  3. jimrr
    jimrr Veteran Member
    1,268
    285
    Jun 12, 2016
    sarasota
    nice cars!!!
  4. 79Zee28
    79Zee28 Veteran Member Lifetime Gold Member
    156
    Jul 6, 2008
    Northern, NJ
    Please post before and after pictures of those rims. Those a beautiful wheels that are so unique today.
  5. budro6968
    budro6968 Veteran Member
    2,662
    363
    Apr 2, 2016
    Jax Florida
    I dug up my old paint code list from Sherwin Williams. This is what I found. This list does not have the chips. I will look at other years to see if that code was used. I only had this part in my office I have another out in the Garage somewhere. Might have chips. Where did you find the WA8150 code at? WA 7022 is the only code for wheels on Chevy listed. Hope you can see this info. I could not get a perfect pic. The other two Silver Met codes I believe are body color and only used the 2 digit code back then.
  6. Twisted_Metal
    26,200
    575
    Those wheels were made by "Western Wheel"... They probably came from Western pre-finished in the colors Chevy used for these wheels. (Black, Gold and Silver)
    Finding a GM paint code might be difficult as they probably didn't actually paint these wheels at a GM plant.
  7. seventy7camaro
    I'm having computer issues... I'll get the after pix on tonite after work.
  8. Twisted_Metal
    26,200
    575
  9. Z28SSRS
    Z28SSRS Veteran Member
    128
    11
    May 2, 2009
    Nevada City, CA
    I don't remember ever seeing the turbine wheels on any Camaro other than 1978 or 79 Z28s.
