1979 Z side vents?
Discussion in '1978 - 1981 Specific' started by Glava, Jan 24, 2018.
  1. Glava
    Glava Veteran Member Lifetime Gold Member
    352
    Mar 23, 1999
    Central NY
    I recently saw a posting in another topic with a member signature indicating that they have a 79 Z with"non- functioning side vents".
    I had seen this referenced in a test drive in an old Popular Hot Roding magazine back in the day, but thought that it was a typo.
    I have a 79 that I have had since September 79, built June 79, and the side vents are open and functioning from the factory.
    Are there functioning and non-functioning side vents?
    Mine is a Norwood build, so I wonder if the vents are open or closed depending on build date and/ or where it was produced?
  2. Zspoiler
    Zspoiler Veteran Member
    2,894
    186
    May 6, 2012
    Federal Way, Washington
    I have an 1979 Z-28 RS Camaro It was built in January at the Van Nuys .California plant.I have belonged to Camaro club and have seen them new. 130044932860518017_26257430996_o (1).jpg And have never seen a non functioning set. I have 1980-81 side vents on mine now.
  3. CorkyE
    9,847
    316
    I bought my 79 Z28 new also and the side fender vents are open but with the inner fender in place, they are closed off and serve no purpose other than looks. I'd guess you could make them functional with some tin work, I haven't seen it done on a street car though.
  4. Glava
    352
    Mar 23, 1999
    Central NY
    These vents are open to the engine compartment and are a great way to get rid of under hood heat. The attached shot is from the engine compartment, behind the inner fender. The vents are between the fire wall and the wheel well liner. You can see the light to the outside of these functional side louvers.
  5. CorkyE
    9,847
    316
    I'll have to take another look when I get my inner fenders back on, I'm in the middle of a drawn out engine swap now.
  6. Zspoiler
    2,894
    186
    May 6, 2012
    You can also see and feel the heat from the engine compartment on a cold day.
