1978 Z28 Tachometer reading way high
Discussion in 'Troubleshooting & Diagnosis' started by w10085, Aug 8, 2017.
  1. w10085
    w10085 New Member
    26
    Oct 28, 2015
    North Carolina
  2. CorkyE
    9,710
    298
    Here's who I used when mine went kaput, Daniel is also a site sponsor. I found it easier just to call him. http://www.gaugemarks.com/
  3. Ihada70Z28B4
    Ihada70Z28B4 Veteran Member
    157
    11
    Oct 4, 2002
    Buffalo,NY,USA
    Most likely your problem, but you can check the capacitor first. If you have access to a signal generator(optional) and can do a little soldering, then fix it and calibrate it yourself. It's very easy to do, I used the method in the second link you posted and the part is a few bucks. If you have an accurate tach to hook up separately you can just adjust the variable resistor you put in and match readings to calibrate. Signal generators make it easier though,and you can test the entire tach scale for accuracy.
  4. Twisted_Metal
    26,128
    553
    Make sure it's not a 6 cylinder tach.
    They will read high consistently across the scale. (4/3 actual RPM)
