1978 LT Progress pictures by Elpres
Discussion in 'Project Progress' started by Elpres, Sep 24, 2008.
  1. clay taylor
    clay taylor Veteran Member
    100
    Dec 8, 2008
    detroit mi
    My 81 goes through that same spot.
  2. Elpres
    Elpres Veteran Member
    1,082
    Dec 18, 2005
    Denmark
    thank you guys for ur help. I finally got the spedo cable installed.
  3. Elpres
    1,082
    Dec 18, 2005
    Denmark
    my 3 piece rear spoiler was previously riveted on and smoothed out with bondo.
    How did you guys attach it?
  4. 436z28
    436z28 Member
    66
    Oct 3, 2011
    grandrapids,mi
    should have studs on the bottom,then u just use lock nuts to secure it in place,good luck getting it mounted hope this helps.plus u need to drill holes for the studs to go thru ur deck lid,if it doesnt have the studs u need to get new ones and epoxy them in.
  5. Elpres
    1,082
    Dec 18, 2005
    Denmark
    ok, ill have to get going with the glassfiber then. :screwup:
  6. 436z28
    436z28 Member
    66
    Oct 3, 2011
    grandrapids,mi
    yeah just cut off the large head on the bolt or if u can find some studs to glass in.i would use about a 7/16 size stud.
  7. Elpres
    1,082
    Dec 18, 2005
    Denmark
    ill work something out. the spoiler do look a bit uneven and worn.. thanks.
  8. Elpres
    1,082
    Dec 18, 2005
    Denmark
    if found this picture.
    I need to know hot this metal tube is attached?
  9. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,019
    Sep 22, 2007
    Blind Bay, B.C.
    I know the lower left eyelet connects to the starter, not sure about the upper eyelet...don't think it will reach the firewall... maybe the the block or exhaust manifold?
  10. 436z28
    436z28 Member
    66
    Oct 3, 2011
    grandrapids,mi
    tube
    be careful,check the wires real good,if theres any bare wire,it will short and cause a fire,most people just throw that metal tube away.
