1978 LT Progress pictures by Elpres
Discussion in 'Project Progress' started by Elpres, Sep 24, 2008.
  1. brooksman9
    brooksman9 Veteran Member
    5,908
    92
    Jun 10, 2007
    Olive Branch, MS
    5 Qts of oil Jakob for the motor. I think about 14 on the tranny but i am not positive.
    EDIT: found two different places that state 10 qts bone dry on the tranny
  2. Elpres
    Elpres Veteran Member
    1,082
    Dec 18, 2005
    Denmark
    thanks Pat. Sounds about right. amazing how much oil the tranny need.. I will need to save up some money to buy all that oil. :)
  3. brooksman9
    5,908
    92
    Jun 10, 2007
    Olive Branch, MS
    Don't forget to fill the torque converter before you put it in. Also turn and make sure it seats/clicks 3 times.
  4. Elpres
    1,082
    Dec 18, 2005
    Denmark
    its already installed, it should be allright. (I hope) thanks Pat
  5. Elpres
    1,082
    Dec 18, 2005
    Denmark
    is it true that the lower front fender extension in not re-produced enymore???
  6. Elpres
    1,082
    Dec 18, 2005
    Denmark
    hinges painted
    fabbed cooler lines
    carb setup.
    stock intake - adapter plate - holley carb
    new hoses installed.
    mock-up of fenders
  7. Elpres
    1,082
    Dec 18, 2005
    Denmark
    I have a breather on the rocker cover, but where should the hose go to??
    I see that others run a hose from the breather to a inlet on the base plate of the carb. But I dont have any inlet on the base plate anywhere?
    help me out??
  8. 81forme
    81forme Veteran Member
    290
    Apr 8, 2010
    Wisconsin
    i dont know if the 78 is the same as an 81 but my spedo cable goes in under the main harness connector and just above the inner fender mount. i can post a pic latter if you would like to see where mine is.
  9. Elpres
    1,082
    Dec 18, 2005
    Denmark
    thanks, that would be great.
  10. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,020
    Sep 22, 2007
    Blind Bay, B.C.
    Not sure if your's is the same, but I'm sure my '73 came through here...
    (Mad Mike's '74 picture)
