1978 fuel delivery trouble
Discussion in 'Troubleshooting & Diagnosis' started by Timbone, Aug 23, 2015.
  1. Timbone
    Timbone New Member
    14
    Aug 22, 2015
    New York
    Hello boys and girls. I just joined this site looks very helpful I just bought a 78 camaro lt type got it for a great deal. I'm having trouble with fuel delivery I changed the fuel filter at the carb changed the fuel pump. No change, fuel not getting to the fuel pump. I was wondering what to do next . IE drop the tank,check the fuel lines, Please help any info would be helpful.
  2. Twisted_Metal
    25,377
    327
    Before you drop the tank... Check the rubber connection to the fuel line near the tank, it could be rotted or kinked.
    If that looks good...
    There is a filter (sock) on the inlet to the fuel feed line inside the tank... If there's no fuel getting to the pump (and there's fuel in the tank) it almost has to be that filter.
    Good Luck
  3. Timbone
    Timbone New Member
    14
    Aug 22, 2015
    New York
    Thank you. I will check it out and let you know
  4. cadillac_al
    cadillac_al Veteran Member
    540
    34
    Apr 22, 2015
    Maine
    I usually blow in the line to see if I can hear it bubbling in the tank. Then I will hook a mightyvac to it and try to suck some gas out. If a rubber line is bad you should be able to hear the vacuum hissing.
  5. Timbone
    Timbone New Member
    14
    Aug 22, 2015
    New York
    Thanks for all the help. It was the rubber hoses in the rear near the tank and the ones under the passenger door. All were dry rotted and cracked replaced all and had to crank the engine for a full minute then it turned over. Again thank you for your advice.
  6. phat80
    phat80 Veteran Member
    988
    Jan 4, 2013
    Victoria BC
    Fwiw
    Personally, I find it's usually the loose nut behind the wheel:)
    Welcome to Nasty stick around, there's refreshments later.
  7. Timbone
    Timbone New Member
    14
    Aug 22, 2015
    New York
    Your welcome.
  8. Gary S
    20,789
    216
    I find that the nut that holds the steering wheel causes other problems like wrecked cars and such.
