1977 Z28 VIN tag has no Z designation
Discussion in '1977 Z28' started by kursed56, May 2, 2016.
  1. kursed56
    kursed56 Veteran Member
    120
    Feb 23, 2006
    Fort Wayne, IN
    I have a 1977, as far as I can tell its all original, paint and all, looks to be the real deal. I was looking at the VIN over the weekend and didn't see anywhere that says its a Z28. Any help would be great. Thanks
  2. djkaplan
    djkaplan Veteran Member
    162
    Mar 27, 2016
    Victoria, bc
    77 Z28 often don't read z28 on the trim tag. Mine dosnt but the build sheet dose. the other ive seen dose read z28 on the trim tag. after looking the two cars if its option bombed it wont.
  3. ls777z
    ls777z Veteran Member
    2,119
    8
    Feb 19, 2000
    Clay,NY
    The "L" means it was built at the Van Nuys plant. It won't say "Z28", only on the Norwood built cars (both of mine). If it's mostly original check for the build sheet. That will confirm it's true identity.
  4. kursed56
    120
    Feb 23, 2006
    Fort Wayne, IN
    Thanks guys. Ill go home and see if its under the rear seats. Be nice if its there.
  5. badazz81z28
    15,434
    227
    Las Vegas, NV
    Yeah, only Norwood cars has those indications on the trim tag. Your best bet is the vin as I think in 77 the engine code was specific to the z28.
  6. Gary S
    21,615
    483
    The "8" designation on the LA cars for Z28 didn't show up until 1978 or possibly very late in the 1977 production year. Don't expect to find it on a '77.
  7. djkaplan
    162
    Mar 27, 2016
    Victoria, bc
    Well I've learnt something new. I can a test to what there saying the car with the z28 on the tag was norwood.
    The build sheet can be under the front seat or ontop of the gas tank aswell. Hears hoping yours is in the back seat. I pulled one of a tank yesterday on my 78 they just get ruined down there.
  8. Z28PILOT
    Z28PILOT Veteran Member Lifetime Gold Member
    2,023
    16
    Oct 8, 2009
    Emerald Isle , NC
    I luv the White 77z s .
  9. kursed56
    120
    Feb 23, 2006
    Fort Wayne, IN
    Thanks again. I looked under all 4 seats tonight, no luck. I don't think its under the dash anywhere either. So eventually Ill have to take up the carpet and/or drop the tank.
  10. nwz28
    nwz28 Veteran Member
    241
    Jan 27, 2001
    New York
    My build sheet for my 77 Z was in the springs of the rear seatback. Check there before giving up! Remove the set bottoms and unbolt the bottom of the seatback. You can then reach up and feel if there is any paper under the metal springs.
