1973 z28 350+.030 strange engine shake !
Discussion in 'Troubleshooting & Diagnosis' started by Lou6t4gto, Jan 24, 2018.
  1. Lou6t4gto
    Lou6t4gto Veteran Member
    329
    15
    Aug 18, 2010
    Ocala, Fla
    I think I remember that I Have put a timing light on it and checked that the advance was smooth. also, I've tried 3 different HEI' s in it in the past few years.
  2. CorkyE
    9,847
    316
    Bonzo has a valid point. Pop the hood when it's dark, have someone (or take the air cleaner off and do it yourself) bring the rpm's up to where the vibration is and see if there is any arcing or cross firing on the spark plug wires. Also check the inside of the distributor cap for arc tracing.
  3. Lou6t4gto
    329
    15
    Aug 18, 2010
    Ocala, Fla
    just installed new plugs, new wires and new rotor and cap ! no difference. had already changed coil and ign module.
  4. cadillac_al
    cadillac_al Veteran Member
    703
    50
    Apr 22, 2015
    Maine
    Is the engine still running smoothly while it's vibrating or is it breaking up/missing?
  5. Lou6t4gto
    329
    15
    Aug 18, 2010
    Ocala, Fla
    pretty smoothly, hard to tell with the shaking. can run the rpm's up,& down and it runs smooth, but stop and keep it at 18-1900 and it shakes every time.
  6. CorkyE
    9,847
    316
    Ugh, sounds like that's going to be a bear to find. Do you have a mechanics stethoscope? Crank the idle up or have someone hold it there while you probe around the front and rear of engine and listen for anything unusual.
  7. bourbon_scotch
    2,153
    79
    Jan 10, 2003
    USA
    take the flex fan off and try it, or just take your belts off and try it with no accessories turning
  8. djorgensen3
    djorgensen3 Veteran Member
    447
    47
    Oct 15, 2009
    Peoria, Az
    Double and triple check the firing order. I mistakenly crossed a couple plug wires once and was super frustrated cuz it had similar symptoms as yours. Don't just go by doing one at a time, actually verify hand over hand with the wires and firing order. Just a thought.
  9. frankz
    frankz Veteran Member
    2,076
    Aug 24, 2009
    Illinois
    Are you certain that both the harmonic balancer and flexplate are zero balanced?
  10. Lou6t4gto
    329
    15
    Aug 18, 2010
    Ocala, Fla
    firing order absolutely correct. Flex plate , definitely neutral. ( hard to mistake a 400 plate for a 350.)and is for a 1st gen 350 2 part seal engine. The balancer is the stock 6 3/4" 0 balance, but Is 43 years old. Seems strange, "Most Sites" say a 350 should have a 8" balancer, but this ones always been on there and when looking at replacement balancers they do come up 6 3/4". But WHY, ONLY at 18-1900 RPM ??? at idle you could put a glass of water on the air cleaner and almost have no ripples). if it was balancing ( the rods were balanced within a gram a long time ago (20 years) along with the pistons. crank was replace when "freshened up" (about 4 years ago). Wouldn't "out of balance" get progressively worse as the rpm goes up ? No, It did not start with the crank replacement. the shake /vibration can be felt in the steering wheel(Standing still, in park).
    unfortunately 18-1900 rpm is right where cruising speed is around town !
    thanks for the ideas.
