1973 RS,LT Z28 question body
Discussion in 'Body Restoration' started by Lou6t4gto, Dec 23, 2017.
  1. Lou6t4gto
    Lou6t4gto Veteran Member
    160
    Aug 18, 2010
    Ocala, Fla
    I've had my 1973 RS LT Z28 (automatic) since 1977. the lower parts of the doors/fenders/1/4s are semi flat back with a chrome molding above. Was that part of "LT" or "RS" option? also, I just converted to rear Disc Brakes ( w /emergency brake), and am going to install a rebuilt 1992 700R trans (driveshaft already cut). What is the best "Overall" rear end ratio for Both in town AND interstate MPG ? I used to drive the car everyday for 30 years, but the gas situation put a damper on that. Engine is orig 350 block +.030, 1970 350 300hp hydraulic cam,Q-jet on performer manifold and dual exhaust with AC. Opinions ?? Thanks
  2. bodymanbill
    bodymanbill Veteran Member
    701
    109
    Feb 1, 2007
    South Park Pa
    The lower moulding with the black underneath was part of the Type Lt model. 373s always seamed like the best all around gear to me. Let's see some pics , I'm building a 73Z Type Lt myself
  3. Lou6t4gto
    160
    Aug 18, 2010
    Ocala, Fla
    will eventually post pics, but it looks like most 2nd gen that are on car mag covers, red/black stripes, Low 1970 Spoiler, black LT interior and is pretty much bone stock, but all rebuilt.
  4. Troy72Camaro
    Troy72Camaro New Member
    Feb 20, 2017
    Maine
    If your looking to be a little snappy with 300hp I'd go 3:73 if you want better MPG go 3:42 great over all gear.
  5. twozs
    twozs Veteran Member
    8,478
    85
    Aug 5, 1999
    hopewell jct ny
    Keep in my mind of your rpm . AC compressors don’t like high rpm . My 2001 Z28 had a ac cut off at like 5000 rpms .
  6. Lou6t4gto
    160
    Aug 18, 2010
    Ocala, Fla
    1973 was hydraulic, first z28 that came with AC. no problems in the 42 years I've owned it.
  7. Blown Camaro
    Blown Camaro Veteran Member
    1,000
    39
    Dec 13, 2009
    Deltona, FL
    I have had my '73 Type LT for 21 years. It never had rocker mouldings as far as I can tell. No holes or studs. I've thought about putting some on it as my '72 RS/SS had them and they looked sharp.
  8. Lou6t4gto
    160
    Aug 18, 2010
    Ocala, Fla
    as I recall the fenders and 1/4s are bolt on clips, the doors are studded w/ screws on the ends
  9. twozs
    8,478
    85
    Aug 5, 1999
    hopewell jct ny
    They also came with 3.42 rear with ac from the factory and 3.73 was not available .it didn’t have to do with the lifters , it was more the compressor shredding itself at high rpm .
  10. McCune
    McCune Veteran Member
    680
    63
    Aug 22, 2015
    st.george utah
    Rear quarters have two studs IMG_0938.JPG IMG_0939.JPG and a clip hole. The front fenders have some mounting holes as well but I will have to get a picture.
