1973 cg code 8.5 10 bolt
Discussion in 'Swap Meet Section' started by lesterpaulstandard, Feb 8, 2018.
  1. lesterpaulstandard
    lesterpaulstandard New Member
    Feb 8, 2018
    gm 8.5 corporate 10 bolt for sale
    axle codes:
    a153-jan 15th 1973
    n1235542b-1973/74 Camaro
    cg g016 4g- on axle tube-3.73 posi
    2 gm 3988517 11 41 12 72 on ring gear
    excellent working order when pulled-no grinding/clunking etc.
    clean insides
    axle shaft bearing surfaces nice/smooth-no gouges
    sandblasted-will be painted soon w/ pics
    new cover
    new axle shaft seals
    this rear was installed in a 69 Camaro I bought and am replacing with the original 12 bolt
    because this was in a 1st gen Camaro the perches were relocated an inch inboard.
    the perches can be rewelded to the original 2nd gen location or bolt in for a 1st gen Camaro/firebird.
    $700 without brakes
    734-972-zero five two zero
    leave message if interested-I will call you back.
    located s.e. Michigan (also on craigslist Detroit)
