1971 Camaro Fan Shroud
Discussion in '1970 - 1973 Specific' started by nasblu, Jan 10, 2017.
  1. nasblu
    nasblu Member
    69
    Dec 5, 2009
    PA
    Are all 1971 Camaro fan shrouds the same regardless of configuration? Does Z28 and AC or any car with VO1 HD Radiator have a different shroud?
  2. twozs
    twozs Veteran Member
    8,480
    86
    Aug 5, 1999
    hopewell jct ny
    2 different shrouds. The one for the 21inch opening and the 26 inch opening . All HD cooling cars ( AC and Z28 included ) had the 26 inch shroud . All non HD cooling (21inch ) had the small shroud . In 71 the big shroud did not have " caution fan " on it ,The later ones did .
  3. nasblu
    nasblu Member
    69
    Dec 5, 2009
    PA
    Was the top radiator mount plate the same on HD cooling cars vs regular cooling cars?
  4. 70lt1z28
    1,415
    158
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Pretty sure in 71 it was different. 70 for sure it was.
  5. nasblu
    nasblu Member
    69
    Dec 5, 2009
    PA
    Can someone tell me what the part# was that was stamped into the top of a 1971 Z28 or AC car larger radiator top mount plate. Its like L 3973--- It was stamped on drivers side. If anyone knows more about these let me know. Like differences in length or width vs standard top radiator mount.
  6. Silver75
    Silver75 Veteran Member
    498
    Feb 27, 2002
    Georgetown, PA
    I believe 904 are the last 3 digits. The earlier top plates carry a different part number than the 75-81 cars.
  7. jbloake
    jbloake Veteran Member
    247
    26
    May 1, 2002
    26"is L 3973904
  8. nasblu
    nasblu Member
    69
    Dec 5, 2009
    PA
    Thanks Guys for all the responses.
