1970 Z28 Leaf Spring questions
Discussion in 'Original Drivetrain Topic' started by 70lt1z28, Mar 26, 2017.
  1. TommyRS70
    TommyRS70 Veteran Member
    835
    16
    Jan 31, 2004
    KY
    Here's a couple from an NOS Gm set I have. Not sure when they were made. See next...
  2. TommyRS70
    835
    16
    Jan 31, 2004
    KY
    Here's a NOS GM set...not sure of production date. 0903172114.jpg 0903172113.jpg
  3. flowjoe
    7,957
    23
    Feb 7, 2006
    SoCal
    Figured this was worthy of being stickied... see under "Various Original Drivetrain Stickies".
  4. l16pilot
    1,661
    82
    Dec 13, 2004
    Hurlock, MD, USA
    Hi Joe!....been a while bud. hope you, Karen and the girls are well. :)
  5. flowjoe
    7,957
    23
    Feb 7, 2006
    SoCal
    We're all good Steve, thanks for asking. Hope you guys are doing well also. :bowtie:
    PS I still have a pair of doors sitting here with your name on them.
  6. CamarosRus
    CamarosRus Veteran Member
    I'm obsessed with coming to a CONCLUSION on what mfg (not any ole dealer)
    can mfg the closest best fit best look 70 Z28 AND 70 L-78 rear leaf spring
    WITHOUT all this re-arching baloney
    Steve....I bought 21-297 springs from DAYTON (via www.SDtruckSprings.com)
    to replace the springs in my 73 R/S LT (L65, T350)
    The 21-297 is the spring that replaces the factory # 480879
    Member JBloake wrote else where that he found the 21-285 to same as
    3930074 ....70 Z28 spring ??????
    Anyway my contact at DAYTON spring says he can make a very close
    21-287 but currently has NO inventory
    I'm trying to pull together all previous postings but not doing a good job...
    Did anyone ever post anything accurately on the 70 L78 rear spring
    or what did Scott K and Mike S buy from EATON
  7. Budz
    2,944
    39
    Mar 17, 2002
    Ashburn, Va USA
    FWIW....I used the Eaton Z/28 leaf springs, but never had them modified in any way. I've never touched the front coil springs though and have had the car 20 years....I'm pretty sure they're the original 48 year old coils.
    I think my cars slightly 'nose down' look is due to the front coils, not the rear leafs, and I believe Eatons springs are correct without de-arching. Check out the vintage Z/28 dealership photos below for comparison. They show a lot more clearance both front and rear above the tires than are on most of our restored Camaros.
    Note: My car has over-sized tires in these pics, but tire size doesn't matter for the purpose of spring stance. The tires are the same size on all four corners.
    Mine
    How they looked when new
  8. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    941
    11
    Jan 1, 2005
    Schererville,In.46375
    Buddy,
    The problem was so bad that you could not hook up the brake line from the diff to body...That why the searching was necessary.
  9. FlaJunkie
    6,065
    113
    Mar 24, 2001
    Rockledge, Florida
    OK, today I took some time and found my original (02C-Norwood) springs. Took some pics of them. They are on my photosite. You can look through them and if you want wicked detail, use the link at the bottom of the page. It is ginormous!
    My Gallery
    Huh. The rubber in the spring mount is:
    GENERAL TIRE B15153 5F-45 3892753
  10. CamarosRus
    FlaJunkie, I also have ORIGINAL 70 Z28 springs that I bought from a local wrecked Z28
    about 25 years ago.
    What we need is to be able to compare what the Aftermarket is offering US
    compared to the GM originals
    I have the aftermarket SRI #'s that match the OE numbers
    For reasons I cant explain DAYTON spring doesnt mfg the 21-285 which crosses
    to the 3930074 2nd design 1970 Z28
    DAYTON does mfg the 21-345 which crosses to a service replacement 480881
    No one I know of is willing to buy this 21-345 from www.sdtrucksprings.com
    and see if/how it fits their 70,71,72,73 Z28 !!!!!!!!!!!!!!
    I still need to discuss/call EATON and DAYTON with the above info and come to my final conclusions.
