1970 z28 gas pedal ?
Discussion in '1970 - 1973 Specific' started by speed_m5, Nov 19, 2016.
  1. speed_m5
    speed_m5 Veteran Member
    1,040
    11
    Apr 17, 2010
    Baytown Texas
    The plastic part that i have not found yet in my stash is it the same as all later models see pic. its missing
  2. COPO
    15,969
    186
    The plastic part has a slit in it and holds the cable in the accel rod.
  3. jbloake
    jbloake Veteran Member
    247
    26
    May 1, 2002
    I believe the part of the hinge for the shaft is missing Later year parts should be the same
  4. ronzz572
    1,781
    36
    Feb 8, 2007
    imperial pa
    Patrick the plastic base should be the same from a hinged type base. When installed you would barely see it under the metal plate.
