1970 Z28 Engine idle problems
Discussion in 'Troubleshooting & Diagnosis' started by harkz28, Nov 5, 2017.
  1. harkz28
    harkz28 New Member
    15
    Aug 22, 2005
    I have a 1970 RS Z28 fresh LT1 350 factory Holley 780. I installed the MSD 8360. Idles fine in park. But when I drop it in Drive Idle Falls very low when warm. The car almost dies. Do I need to recurve this distributor adjust the carburetor not sure what to do next?
  2. restore-z28
    restore-z28 Veteran Member
    378
    59
    Jul 4, 2010
    Vancouver, BC
    Start with making sure your base timing is correct, the I would move onto the carb adjustment. You might be too lean on your air/fuel mixture and the double check your base idle. Might even be a jetting issue, are you running stock jets? You might need to increase the jet size.
  3. Dave Nelson
    Dave Nelson Veteran Member
    3,860
    1,258
    Dec 19, 2003
    Vineland N.J USA
    Were any changes made to the vacuum advance?
  4. Gary S
    21,637
    489
    Remember that with an automatic tranny, the idle speed is set with the tranny in Drive. The idle speed in neutral doesn't matter unless it is extremely high.
  5. harkz28
    harkz28 New Member
    15
    Aug 22, 2005
    Thanks for your replies, stock jets in the Holly and the distributor was installed Straight Out of the Box didn't adjust the curve at all. What should idle be in Drive about 650-700?
  6. Gary S
    21,637
    489
    The tuneup specs for your engine should be on the sticker on the top of the radiator panel.
  7. twozs
    twozs Veteran Member
    8,813
    165
    Aug 5, 1999
    hopewell jct ny
    Don’t they ( auto transmissions) cars have a fast idle solenoid from the factory ?
  8. Gary S
    21,637
    489
    Some do, some don't. Usually the fast idle solenoids were used for handling air conditioning loads or for later smog engines. In 1970, it probably wasn't needed to handle the tranny and it wasn't needed for smog purposes like 1971 and later.
  9. COPO
    16,879
    372
    Set this?
    Turn adjustment screw until it just touches the throttle lever and turn 1/2 turn more to position the valves.
  10. twozs
    8,813
    165
    Aug 5, 1999
    hopewell jct ny
    Is says right on the sticker you provide to set the solinoid screw on auto trans .
