1970 RS Z28. Running a factory LT1
Discussion in 'Troubleshooting & Diagnosis' started by harkz28, Nov 19, 2017.
  1. ronzz572
    Feb 8, 2007
    imperial pa
    I would check the fuel pump pressure the carb float levels just to clear them as the source 1st. Is it a misfire surge as a jerking sensation surge? Or a lack of fuel where it goes flat, Boggs down and looses power and surges back. Identifying what type of surge may help you get a answer as to where to start.
  2. harkz28
    harkz28 New Member
    Aug 22, 2005
  3. hogg
    hogg Veteran Member
    Dec 29, 2000
    Check your gas cap,make sure it is vented. Also i had a rubber hose at tank that was week and would stop up the line when runging hard.
  4. COPO
    With today's gas you need to change the rubber lines to fuel injection rubber.
    SRGN likes this.
  5. harkz28
    harkz28 New Member
    Aug 22, 2005
    Adjusting the spark plug gap .40 seems to as hell have helped. Next Step Up with the Jets in the carburetor
  6. SRGN
    SRGN Veteran Member
    Feb 20, 2009
    Central NJ
    Solid advice. If the lines are old and deteriorating, they may allow the fuel pump to draw in air without allowing fuel to leak out as well. Or even collapse if you're in a high fuel demand situation. Regardless, a good idea to change them.
  7. Tphil413
    Tphil413 Veteran Member
    Jun 1, 2007
    San Francisco, CA
    I'd check your fuel filter. I experienced the same surging once when my fuel filter was partially plugged, dirty. Didn't show up at slow speeds but at freeway speed when I accelerated.
