1970 RS Z28. Running a factory LT1
Discussion in 'Troubleshooting & Diagnosis' started by harkz28, Nov 19, 2017.
  1. harkz28
    harkz28 New Member
    15
    Aug 22, 2005
    1970 Z28 LT1 Stock Holley 780 MSD ignition. When running at 70 on the freeway feels like the car is surging. Car seems to run fine on side streets at normal speeds. Any ideas?
  2. COPO
    16,456
    290
    Don't gap the plugs wider than .040 with MSD on a 70 LT1. Ask me how I know.
  3. BonzoHansen
    I'll bite. How do you know?
  4. COPO
    16,456
    290
    Cause I tried .045, .040 and .035 with my MSD 6420 and .045 gave me a hesitation above 2500 rpm and up cruise and even a gradual increase in rpm from a dead stop.
  5. SRGN
    SRGN Veteran Member
    458
    142
    Feb 20, 2009
    Central NJ
    Without a wideband to verify air fuel ratios, you can't be 100% positive it was the ignition system alone. Lean mixtures are notoriously difficult to ignite.
  6. COPO
    16,456
    290
    Get the highest vacuum reading on your idle mixture screws too. Not everyone has a W/B, that makes it too easy. I don’t and won't drill a hole for one. We never had them in the 60’s and early 70’s when HP was at it’s peak on leaded Sunoco 260 fuel and we got by.
  7. SRGN
    SRGN Veteran Member
    458
    142
    Feb 20, 2009
    Central NJ
    You don't need a hole, they make a tailpipe clamp if you were so inclined to use one. Technology has advanced considerably since 10mpg, 250hp cars were built. I choose to embrace it and reap the benefits.
  8. COPO
    16,456
    290
    IMO, the tailpipe is too far away for an accurate reading.
  9. 70lt1z28
    2,117
    274
    Oct 3, 1999
    Beavercreek, Ohio, USA
    For something like the stock exhaust on a 70, I would not be afraid of taking an old heat riser and moding it for the sensor. Bolt it in, take readings and adjust and them put the original back in. Yeah, its a bit of work, but what isn't.
  10. COPO
    16,456
    290
    I would leave the moded heat riser in place.
