1970 ONLY
Discussion in '1970 - 1973 Specific' started by 67johnny, Dec 27, 2017.
  1. 67johnny
    67johnny Veteran Member
    104
    Apr 14, 2016
    vancouver
    The 1970 L78 cars had a special tachometer option. (5700 yellow line/6500 red line in a 7000 RPM format)
    Was also wondering if the 70 rear one piece low spoiler option showed up on any early 71 production models?
  2. 70lt1z28
    2,252
    320
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Rear spoiler could be low or high in 71. High was now an RPO instead of COPO. I think it was D80 low D88 high?
  3. 70lt1z28
    2,252
    320
    Oct 3, 1999
    I think 71 had it too, but A pillar cover finish is smooth instead of textured.
  4. 70lt1z28
    2,252
    320
    Oct 3, 1999
    Along with the gas tank stuff I posted earlier is the single 3/8 fuel line without a return line to tank. This then also leads to the 70 only fuel pump with no return connection. Just try to find one of those NOS sometime.
  5. servello2005
    servello2005 Veteran Member
    170
    21
    Jun 22, 2013
    toronto ontario
    how about TCS switch pin type thats on the muncie trans side cover 70 only.
    70lt1z28 likes this.
  6. 67johnny
    104
    Apr 14, 2016
    vancouver
    1970 RPO code D80 = Spoiler Rear Deck > at a cost when ordered for your 1970 was $32.65.
    I do seem to think the 71 used the same RPO D80 code to option the spoiler but, it got you a front spoiler for the 1971 Camaro's as well.
    Maybe we can do a confirm on this?
  7. 70lt1z28
    2,252
    320
    Oct 3, 1999
    OK. I'm just not sure how it worked to specify what size rear spoiler. Was it still D80 or was there another code for the tall spoiler option?
  8. ggtsvnv
    ggtsvnv Veteran Member
    939
    10
    Jun 20, 2002
    Reno NV,
    How about the 10 bolt rear end? Wasn't 70 the 8.2 inch and the 71 and up the 8.5 GM corporate?
  9. 70lt1z28
    2,252
    320
    Oct 3, 1999
    Yes i believe you are correct. Good one
  10. hogg
    hogg Veteran Member
    3,150
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    When did they start putting foam in rear seats , i know my two 70's where made of cloth,inside and had no place , indentions,for rear seat belts made into them. I know by 73 they had foam.
