1970 Fender Emblems
Discussion in '1970 - 1973 Specific' started by Me_n_my_z, Jan 10, 2017.
  1. Me_n_my_z
    Me_n_my_z Veteran Member
    272
    8
    Jan 2, 2011
    Cleveland, Ohio
    I want to change my emblems on my front fenders... Whats the best way to go about it?
    Do I have to remove fenders????
    Thanks
  2. FlaJunkie
    5,759
    49
    Mar 24, 2001
    Rockledge, Florida
    Back when the car was young (and so was I) I would unbolt the bottom and top rear fender bolts, pry the fender open and block with a small 2x4. Then I'd stick my skinny arms in and make the swap. :)
  3. Smokin'Joe
    Smokin'Joe Veteran Member Lifetime Gold Member
    541
    11
    Aug 14, 2008
    Texas
    Not long ago I found some original black "SS" emblems for my 1970 Camaro and wanted to swap them out for the white ones on the car.
    I used the method FlaJunkie mentioned above, but ended up having my girlfriend do the brunt of the work as her arms were much smaller than mine. - Even with that, here arms were scarred for days after all the sharp objects up inside. - Although it can be done this way, I might advise you would probably be ahead of the game by removing the fender completely, or at least taking out a few more bolts than just the top and bottom rear, and I think we took out the bolts to the inner fender wheelhouse lip as well.
    Good Luck !
  4. badazz81z28
    14,179
    110
    Las Vegas, NV
    By removing the inner fender you should be able to reach the nuts on the back
  5. COPO
    15,969
    186
    I did it the same way without unbolting the top.
