1970 detail question?
Discussion in '1970 - 1973 Specific' started by 67johnny, Jun 28, 2017.
  1. 67johnny
    67johnny Member
    95
    Apr 14, 2016
    vancouver
    Hey all!
    On the 1970 Camaro NON RS .
    Regarding the 396 engine mounts , one stand has round hole and one is slotted where the motor mount long bolt goes thru .
    To confirm...Is slotted on the pass side?
    Also...is the front plate bracket retained with plastic grommets or?
    this one>
    http://www.camarodepot.ca/exterior/...icense-plate-bracket-front-standard-1970-1973
    Assembly manual is AWOL!
    Thanks.
  2. jbloake
    jbloake Veteran Member
    257
    32
    May 1, 2002
    NS Canada
    Mount ___307 is on DS and
    It think it's ____886 on PS
    That's the correct bracket for the std front plate
  3. jbloake
    257
    32
    May 1, 2002
    NS Canada
    image.jpg The oval hole is on the RH side mount 886.
  4. 67johnny
    67johnny Member
    95
    Apr 14, 2016
    vancouver
    Thanks for the speedy reply!
    Those are my mount numbers and all looks good!
    In regards to the plastic grommet... (#4 in the detail) does anyone sell them?
    I have only one and its looking mangled and they are a lot thicker than the ones that typically hold on license plates!
    GM laughed of course !
  5. Gary S
    21,080
    305
    You can likely find those or similar plastic grommets. There are companies that specialize in making most of the small hardware parts like that for replacement. My local paint and body supplier has rack after rack of those little parts in their showroom. If you take some time to look through what your local shops have, you might find just what you need.
