1970 Camaro Z28 Vin Tag / Cowl Tag
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by 67SS70Z28?, Aug 26, 2017.
  1. 67SS70Z28?
    67SS70Z28? New Member
    12
    Aug 26, 2017
    Is the last digits of the VIN number "sequence number" suppose to match the numbers in upper right corner of the cowl tag.
  2. badazz81z28
    14,602
    158
    Las Vegas, NV
    no, The cowl tag is a body, the VIN is the build sequence
  3. 67SS70Z28?
    12
    Aug 26, 2017
    ok that is what I was thinking just wanted to confirm. If you had questions on trying to confirm if a car was real Z28 what thread would you post them in, I'm kind of new to this site.
  4. 70lt1z28
    2,119
    274
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Vin,Trim Tag and Drivetrain Decoding forum for determining what the TT means or if the VIN is in sequence with the build date. Other questions may go in Original Drivetrain or elsewhere.
  5. badazz81z28
    14,602
    158
    Las Vegas, NV
    Only one way....Documentation. Only Norwood cars has "Z28" on the trim tag. Any car can be faked...Only the paperwork will prove it. Some people are bad at faking Z28s and there are tell-tell signs.
  6. Budz
    2,930
    37
    Mar 17, 2002
    Ashburn, Va USA
    FYI....VIN and Trim Tag technical decoding info here---> http://www.nastyz28.com/decode.html
    As mentioned above, asking Q's in the Original Drivetrain section is probably your best bet for help determining if it's real or not. It's a lot easier if it's a Norwood car since Z/28 is identified on the trim tag. LA cars don't have Z/28 identified on the trim tag.
    Original Drivetrain Topic--> http://www.nastyz28.com/forums/original-drivetrain-topic.31/
  7. 70lt1z28
    2,119
    274
    Oct 3, 1999
    Also know that prior to June 1970 it was missing the Z on the Z28 in the trim tag. It would look like 28.10 (white stripes) or 28.19 (black stripes)
