1970 Camaro Project - Seattle Area
Discussion in 'Project Progress' started by Ribbs, Apr 28, 2013.
  1. Thanks for the response
    Cheers
  2. Ribbs
    Ribbs Member
    55
    Aug 12, 2012
    Seattle, WA
    Finally getting around to working on the car. Wiring is almost complete and I finished up the install of the DSE springs in the rear. Out with the stock - in with the lowering. I like the look.
    Before:
    After:
  3. smokeatr23
    smokeatr23 Veteran Member
    175
    Dec 24, 2014
    United States
    I like the look too. What spring combination are you using? how much drop front and rear?
  4. Ribbs
    Ribbs Member
    55
    Aug 12, 2012
    Seattle, WA
    Up front, I have:
    QA1-52418 CONTROL ARM KIT UPPER STREET
    QA1-52420 CONTROL ARM KIT LOWER STREET
    QA1-52882 SWAY BAR
    QA1-GS501-10400C KIT GM PRO COIL ALUM S-ADJ
    In the rear, I have Detroit Speed (DSE) 3" Drop - P/N: 040102.
  5. Ribbs
    Ribbs Member
    55
    Aug 12, 2012
    Seattle, WA
    Oops, forgot the 2" drop front spindles too.
  6. smokeatr23
    175
    Dec 24, 2014
    United States
    I knew i wanted 2" up front but, wasn't sure in rear. Does that make her sit pretty level? Are the control arms stock geometry, do they add any to the lowering? Looks great, love the color too.
  7. Ribbs
    Ribbs Member
    55
    Aug 12, 2012
    Seattle, WA
    The control arms are stock geometry. The coil over shocks give several inches of lowering so you can set the ride height to anything you want (level or whatever). The QA1 products are good.
  8. broahnazki
    broahnazki Veteran Member
    232
    14
    Jan 19, 2014
    los angeles
    Just seen your entire thread man looks awsome! Nice work
  9. Ribbs
    Ribbs Member
    55
    Aug 12, 2012
    Seattle, WA
    Slow going, but door panels are complete and glass is installed. Interior is basically finished and I like the way it has come out. A bit more wiring in the dash and in the engine compartment and the maiden voyage will be in the offing.
    71RSLS likes this.
  10. CamarosRus
    CamarosRus Veteran Member
    Chuck from Auburn, WA here..........
    What brand seat covers and who locally installed them ?? as I need installation
    for my LEGENDARY Covers!!!!!
    What brand Door Panels and are those new Door Handle Pulls by OER ???
