1970 and 1971 Camaro Horns
Discussion in '1970 - 1973 Specific' started by nasblu, Nov 15, 2016.
  1. nasblu
    nasblu Member
    69
    Dec 5, 2009
    PA
    Do 1970 and 1971 Camaros use the same Horns? If so what are the high n low note horn numbers. Thanks
  2. Gary S
    21,076
    305
    1970 Camaros had dual horns standard. 1971 Camaros had a single horn, and the option list does not show any option to order a second one.
  3. nasblu
    nasblu Member
    69
    Dec 5, 2009
    PA
    I did not know that thanks for the info. Did all 1971 camaros get the 289 low note horn mounted on the passenger side then? Did all 1971 Camaro radiator supports only have one hole for the horn wire or still have two holes only one got a grommet and wire passed through?
  4. COPO
    16,321
    258
    My 1970 L is 9000 289. I can't make out the other horn after 9000.
  5. 71RS6SPD
    71RS6SPD Veteran Member
    203
    Nov 14, 2016
    I have a 71 RS and there was a single horn but there are wires for 2 coming from the harness on either side of the support about 12" apart. I still have the original horn but cannot see the numbers on it.
  6. badazz81z28
    14,554
    149
    Las Vegas, NV
    Im still getting around to research this, but I'm thinking the 1969 and 1970 horns are the exact same. 71 and up are different.
  7. roeville
    roeville Veteran Member
    1,091
    37
    Oct 9, 2000
    SF East Bay CA
    My 71 has a single, passenger side mounted, 289 low horn. (I like reviving old threads).
    Even though the 1971 Camaros have only one horn, the horn harness is the same as 1970 — with connectors for two horns. There are two holes in the radiator support for the RH and LH horn wires but only the passenger side is used and only the passenger side has a wire grommet.
  8. TommyRS70
    TommyRS70 Veteran Member
    740
    10
    Jan 31, 2004
    KY
    289 and 290 for 1970 on mine.
