1970-73 camaro part.
Discussion in 'Swap Meet Section' started by john Gialanella, Aug 19, 2014.
  1. john Gialanella
    john Gialanella Veteran Member
    235
    Oct 15, 2008
    Bloomfield N.J.
    For sale. I have pictures of all these parts. (Please send your e-mail and I will send pictures of the Parts.). Please do not text me because I do not own a Cell or smart phone. Or call 973-748-9443.
    1A Original 4 speed muncie reverse lockout rod. $3975618 in very nice shape. It says 0-5618 on the rod. I have pictures to send. $260.00.
    1. NOS 1970-73 Camaro front lower valance panel #327536. This one is the one that has the two inner braces for more strength. Has GM sticker on it. $400.00. (I paid $450.00.)
    2. NOS 396, 454 & Z-28 motor mounts. and nice repro BB frame mounts with Part numbers on them. Motor mounts say Gold/Nut #3968700 Black, then #3862748 Dark Green, then #3962740 Gold. Underneath that it says #3974735 Gold/nut. They come with all the bolts, washers and nuts to mount both mounts. The frame mounts are reproduction with the correct part numbers on them. They are in very nice condition. $320.00.
    3. NOS in Box 1970-81 Camaro trunk lock latch This is the part that the rod from trunk lock slides into and releases the trunk lid when you use key. $50.00. #9808480.
    4. Blasted and painted nice drivers side Wheelwell to firewall bracket. #3973981. comes with all the bolts, nuts and clips to mount to Wheelwell and firewall. $30.00.
    5. Original in nice shape center caps for 6 slot 14 x 7 inch rally wheels. These are the early ones in metal, not plastic. They are in nice shape. 4 center caps for $100.00. They went on SS and other camaros. Fit 70-81.
    8. NOS TH 400 transmission mount for 1970-74 Camaro Z-28 cars. or any SS Camaro's with TH400 trans. Has #3872247, 3872248, #3895831 inbossed in rubber. Says Pink, Black & Green on one side and Orange on the other side. $200.00.
    9. Really nice used, but restored water pump pulley #3932402. They went on 1969-70 Camaro cars. 350, 327 and 396 engines. It was cleaned up and painted. No rust at all. Says 3932402 DU on pulley. $25.00.
    10 2 NOS subframe bushings #3914802 for 1967-69 Camaro's, but can also be used for 1970-81 Camaro's, since it is exactly the same as #3962720 bushings. $20.00 for the pair. says #3914802 on the side, plus Chevrolet.
    11. Reproduction of TH400 cooler lines for 1970-72 Camaro in stainless steel. $60.00.
    12. Nice reproduction of the 1970-72 BB Camaro upper radiator hose. Has #3973192 on the hose. $15.00.
    13. I have LH & RH windshield lower black molding for 1971-81 Camaros One pair is new reproduction for $30.00. And one pair is NOS GM #3062231 & 3062232 with GM tags. for $60.00. Can also be used for 1970.
    14. AC Delco drivers side temperature sending switch for gauges.1970-81. $15.00.
    15. NOS original GM horn relay #1115889. in canister. Says 889 underneath metal base. $70.00.
    16. NOS GM TH 400 transmission mount for Camaro, Nova, Chevelle. Original numbers were #3872247, #3872248 & #3895831,then #334529, and #2268 and #2269. For BB cars or Z-28 with TH400 transmission. including LS6. I can send pictures, plus any measurements you need. Has green paint on it. $70.00.
    17. AC Delco Headlight switch New GM Made in Mexico $10.00. For 1970-81 cars. (I will include a used but good shape headlight switch knob for 1970 only)
    18. Nice reproduction of rear 9/16 inch inner sway bar bushings $35.00 for pair. For 2 bolt drop links 1970-74.
    19. GM AC Delco NOS TH 400 or TH 350 TCS transmission switch #8683502. 1970-72. $12.00.
    21. used, but in very nice shape 1970-78? Camaro passenger side inner window sweep. It screws to the inside of the door, and rests against the outside of the door glass so water will not go inside door. $20.00. It is in such nice condition.
    22. Original Camaro inside window crank handle. Mint has #20037599 on the inside of the handle. Chrome is excellent. $35.00.
    23. Temperature switch (drivers side) for 1970-81 Camaro's with telltale lights. $10.00
    24. NOS 1971-72 Camaro BB lower radiator hose. #3959486. $50.00.
    26. Original passenger side parking light from 1970 Camaro. Works fine. $10.00.
    27.
    28. I have had for years a walker tailpipe for single exhaust just like originals. It is in perfect shape. It is for 1970-81 Camaro's. $10.00.
    29. Camaro BB intake manifold bolts for aluminum intakes. But they can be used with 1970 L-34 & 1971-72 LS3 BB camaro's with iron intake manifolds. $13.00.
    31. GM Used, but in very nice condition Camaro steering Coupler or rag joint. 3/4 inch diameter, 15 spline count with flat spot. not sure what years for. $15.00.
    32. New original accelerator bracket #326564 which was used in 1970 for all camaro's with 4 barrel carb, (excluding Z-28) plus 1971-73 Camaro's with 4 barrel carbs. it also was used till 1976 on many Chevy cars with 4 barrel carbs. Plus it comes with correct green return spring. $25.00.
    34.
    35.
    Please send e-mail so I can send pictures of the parts.
    Thanks John.
  2. Double R Restorations
    2,700
    47
    Jan 11, 2002
    VA
    Can you send me a pic of the shifter plate? Thanks, Russ
  3. Gary S
    21,628
    487
    John,
    Is this the manual tranny starter with the small cast iron nose to fit the 621 bell housing with a 4 speed or is it the large aluminum nose starter for automatics?
  4. Dave Nelson
    Dave Nelson Veteran Member
    3,859
    1,251
    Dec 19, 2003
    Vineland N.J USA
  5. volsfan
    volsfan Veteran Member Gold Member
    2,580
    Jan 4, 2008
    daytona beach, fl
    That means he sent you a private message. Top right part of the page is where they are located.
  6. Gary S
    21,628
    487
    John,
    This site has pictures of the different starter noses.
    http://rmcavoy.freeshell.org/starters.html
    His 4th picture is of the cast iron nose for manual tranny. His 7th picture on the page is of the aluminum nost starter for automatic trannys.
    I'm interested in getting one of the cast iron ones for manual tranny.
  7. boardog
    boardog Veteran Member
    893
    10
    Dec 8, 2006
    north ga
    pm sent on the rear sway bar items
  8. Gary S
    21,628
    487
    Thanks John. I have one like that for an automatic, but could use one of the 4 speed ones. I'll just keep my eyes open until one shows up.
  9. johnzz28
    johnzz28 New Member
    Sep 8, 2014
    vancouver
    Hey I pm you thanks
