17X9 w/5.5BS
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by ErikNORCAL, Mar 3, 2018.
  1. ErikNORCAL
    ErikNORCAL Veteran Member
    1,023
    Aug 6, 2003
    now in VA
    Set of wheels available near me with the specs in title. These would actually go on an '80 Trans Am but generally same as a Camaro. Thoughts on the backspacing?
    Was interested in at least a 285/40R17 in the rear, maybe in the front too
    if they'll fit.
    Have access to a 17X9.5 wheel w/5.5BS with a 285/40R17 on it. Thinking of using it to test fit. Used the calculator in the sticky and if I'm reading it right, the 17x9.5 will move outboard by about 0.3" in comparison to the 17X9.
    Should be good for a mock up comparison?
  2. Tpichevy
    Tpichevy Veteran Member
    442
    14
    Jun 21, 2016
    Boise id
    Interested in what people say.... subscribe
  3. nobreaks254
    nobreaks254 Veteran Member
    448
    Jul 14, 2007
    aberdeen, SD
    1. if both wheels have the same backspace, the wider wheel will stick out whatever the difference is in the width. So in this case .5, correct? The 285/40 should work fine in the rear but cant say about the front, Ive never tried to fit that wide a wheel on the front yet. I do have a 8.5 with 5.25 BS on my Camaro but with a 255 tire.
  4. camaro71/holland
    1,016
    40
    Aug 27, 2003
    The Netherlands
    From a different topic. Hope it's useful for you.
  5. Todd80Z28
    11,059
    72
    Jun 11, 2002
    Northern VA
    I ran 17x9 with 5.5BS up front for a bunch of years, and it was a very snug fit. 0.25" either way was a rub- 5.25" on the fender lip, 5.75" on the frame. That extra 0.5"...You might get lucky... might.:)
    In the back I don't think it will be an issue. I ran my 17x9 at 5.0 in the back.
