153 or 168 tooth flywheel?
Discussion in 'High Performance Modifications' started by Wolfman911, Apr 29, 2014.
  1. Wolfman911
    Wolfman911 Member
    50
    Oct 29, 2013
    Simpsonville, SC
    Hello all,
    I am gathering parts to build a new short block to go into my 79 Z28. I am looking to build a one piece rear seal 355 with six inch rods. I intend to buy a fully balanced Eagle rotating assembly, but I need to choose between a 153 tooth flywheel or a 168 tooth flywheel. The engine that is in the car now is a '73 block casting number and I do not know what sized flywheel it has. Are there any performance advantages between one flywheel or the other? And are there any fitment issues besides the starter? Any help would be appreciated. Thank you.
  2. TACK
    TACK Veteran Member
    166
    Jan 2, 2012
    dandridge,TN
    153=better acceleration....'68 rs z28 has what u need for manual trans..use the clutch
    And starter from the same..'68 302 3speed
  3. hhott71
    hhott71 Veteran Member Lifetime Gold Member
    14,375
    Mar 30, 2001
    Joplin Mo. 64801
    Use the 168 tooth flexplate.
  4. K5JMP
    so is the only difference the tooth count?
    is the flywheel diameter (not counting the ring gear) and weight the same?.. as in inertial mass?
    if so, how would you gain any performance advantage by using one over the other?
    an inquiring mind wants to know!:dumper:
  5. TACK
    TACK Veteran Member
    166
    Jan 2, 2012
    dandridge,TN
    U can get a neutrl balance flywheel..less teeth quicker acceleration
  6. K5JMP
    less teeth?.. really?
    if a SBC is internally balanced, the flywheel should be neutral to begin with...
    please, tell me more...
  7. Fbird
    2,432
    99
    Feb 12, 2011
    atlanta, ga
    teeth vs weight = MOOT
    2 serparate issues. You can get a 40lb 153 tooth or a 40 lb 168 tooth.
    weight of the flywheel can be good or bad just depends on YOUR combination of vehicle and TORQUE curve of YOUR engine.
    Number of teeth on the flywheel is for STARTING the engine. the more teeth on the flywheel= more torque advatage for the starter motor. END
  8. K5JMP
    I used to play with dirt track late models.. we used an aluminum "shaved" flywheel to get faster revs.. less inertial mass so it revs quicker.
    but you had to drastically increase the idle speed just to keep them running...
    so is a stock 153 and a 168 flywheel the same dimensions with exception of the ring gear?
  9. 70Camaro406
    70Camaro406 Veteran Member
    739
    May 4, 2006
    Cadillac, MI
    No. The teeth are the same and spaced the same. 153 has less teeth, therefore it is smaller in diameter and lighter. That's one of the reasons that blocks have different holes for the starter, so it can be adjusted according to the size of the flywheel/flexplate.
  10. K5JMP
    so how does a "dual drilled" starter work on both flywheels?
    serious question here..
    the relationship to the centerline of the crank doesn't change...
