130 mph speedo swap to 150 mph
Discussion in 'Gauge Marks' started by tbs04, Mar 29, 2014.
  1. tbs04
    tbs04 New Member
    16
    Mar 29, 2014
    Nashville, TN
    I am swapping a 130 mph speedo for a 150 mph speedo. What is the difference between them other than the face plate? Do I need to have it re calibrated to my TH350 trans drive/driven gear?
    Any help is appreciated
    Thanks
    Tim
  2. Twisted_Metal
    25,386
    327
    The speedometers should swap with no other changes required.
    Speed accuracy is achieved via proper transmission gears.
    Adjusting for a speedometer/odometer variance is the only thing that would require speedometer recalibration.
    Welcome to NastyZ!
    Good Luck!
  3. tbs04
    tbs04 New Member
    16
    Mar 29, 2014
    Nashville, TN
    Thanks TM
    So I can take the face plate off the 150 and put it on the 130?
    TIA
    Tim
  4. Gary S
    20,803
    222
    You cannot change the faceplate on the speedometers with a different one as that will cause it to read wrong.
    You can directly swap different speedometers without causing error.
  5. mgoad1971
    mgoad1971 Veteran Member Lifetime Gold Member
    2,471
    Jul 29, 2011
    Houston, Texas
    ^this. And glad you asked!! Think of swapping your tachometer face for your speedo face, just ain't gonna work.
  6. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    You can swap the faces, however, it may be difficult to find a speedometer shop to have it recalibrated.
    Back when I first installed a tune port in my Camaro, I used the '81 gauge housing and speedometer head for the VSS and had to have it recalibrated when I swapped to the 150 face.
    It is still in use to this day, though the VSS is no longer active, I'm using a 40 pulse VSS kit from jags that run.
    The arrow shows the bar that is turned one way or the other to either tighten or loosen the tension of the spring. This is used to calibrate the speedometer.
  7. tbs04
    tbs04 New Member
    16
    Mar 29, 2014
    Nashville, TN
    Thanks for the info!
    Leonard,
    Thanks for the info! The speedo goes out Monday for Calibration!
    Time to finish the rebuild and Bumble Bee will be alive.
    Timothy Smith
  8. Leonards78LT
    1,031
    Jan 21, 2001
    Central Oklahoma
    Glad I could help. I'm no expert, just some tidbits of information I learned along the way. :)
  9. david_396
    david_396 Veteran Member
    211
    May 10, 2002
    Hanford CA
    How did this work out? Price for calibration?
