-12 Tubing Help
Discussion in 'High Performance Modifications' started by badazz81z28, Oct 14, 2017.
  1. badazz81z28
    14,567
    150
    Las Vegas, NV
    I'm looking to hard line my oil tank vent because the hose would be too short to bend where I need it. Going to hard line, but for the life of me I can't fine -12 (3/4") Aluminum Tubing!
    I found Fragola sells the -12 Tube Nuts and Sleeve, but where is the tube? All I could find was some dorman tube for AC, but its like 0.080" wall and I think something more malleable (.035" or so)
    Thanks
  2. Green hornet
    Green hornet Veteran Member
    1,278
    186
    Oct 11, 2015
    North Bay, CA
    How about using copper tubing? I don't know what the wall thickness is. Just a thought.
  3. 71RS/SS396
    71RS/SS396 Veteran Member
    2,598
    20
    Aug 26, 2008
    Wake Forest NC
  4. jimrr
    jimrr Veteran Member
    1,173
    255
    Jun 12, 2016
    sarasota
    Did you try mcmaster-carr?
  5. badazz81z28
    14,567
    150
    Las Vegas, NV
  6. badazz81z28
    14,567
    150
    Las Vegas, NV
    What about a tube bender, can't find anything for light duty use
  7. Turbo70Camaro
    2,112
    103
    Jan 7, 2005
    so cal
    Probably need a conduit tubing bender type of equipment for 3/4"
  8. badazz81z28
    14,567
    150
    Las Vegas, NV
    No....-12 is a common automotive race fitting. There's got to be something other then indoor wiring tube Benders. Besides I noticed all of that tube and copper tube I saw at lowes is advertised as ID.
  9. Goat
    1,779
    19
    Jun 7, 2001
    moncure, NC
    By definition tubing is sized by od and pipe by ID. Lowes is retarded. I agree with above post, 0.035" wall tubing in a soft metal is asking for trouble - especially with something as big as 3/4"...
  10. badazz81z28
    14,567
    150
    Las Vegas, NV
    Richard it's just a vent though, nothing but escaping air in the oil tank
