10 bolt chevy setup questions.
Discussion in 'Transmission & Driveline Topics' started by 7/3-SplitRS, Jul 16, 2018.
  1. camaro71/holland
    1,093
    48
    Aug 27, 2003
    The Netherlands
    Simoultaneous answer with BGH. 0.005 seems the consensus ;)
  2. 7/3-SplitRS
    7/3-SplitRS Veteran Member
    209
    22
    Mar 26, 2014
    Pecatonica IL
    Ok, thanks for the input guys. I will work on getting it back apart and losing a little shim along the way. Much appreciated.
  3. 7/3-SplitRS
    209
    22
    Mar 26, 2014
    Pecatonica IL
    Tore the rear end apart. Shims were at .040. Dropped to .035. Will have to wait for new crush sleeve to show up. Should be here in a couple days. Did get the axle bearings and seals installed. Started looking over the rear disc brake kit I have. Hope all goes well and I will be buttoning this thing up by next weekend.
  4. camaro71/holland
    1,093
    48
    Aug 27, 2003
    The Netherlands
    Don't use a crush sleeve untill the final build! Pre-load the bearings without it and run the pattern, then post the pics agin.
  5. big gear head
    big gear head Veteran Member
    6,072
    42
    Jul 30, 2001
    Central City, Ky.
    I thought I covered that in post number 6. Don't use the crush spacer until you have the pattern correct and you do the final assembly. Also, save the new pinion nut for the final assembly. On the final assembly smear some RTV sealant into the splines of the yoke, NOT THE PINION SHAFT, and use red Locktite on the threads when you install the nut.
  6. 7/3-SplitRS
    209
    22
    Mar 26, 2014
    Pecatonica IL
    You did. Another 3 dollar mistake. I will mock up without it and check again. So when I mock up the rear end without the crush sleeve am I still shooting for the same inch pound rating on the yoke?
  7. camaro71/holland
    1,093
    48
    Aug 27, 2003
    The Netherlands
    Correct.
  8. big gear head
    6,072
    42
    Jul 30, 2001
    Central City, Ky.
    Yes, be sure that you set the bearing preload the same as you will for the final assembly for every trial set up.
  9. 7/3-SplitRS
    209
    22
    Mar 26, 2014
    Pecatonica IL
    Ok. New setup. No crush sleeve. Everything set to spec with .005 less this time. Let me know what you guys think. Thanks alot. 20180727_141809.jpg 20180727_141803.jpg 20180727_141756.jpg 20180727_141746.jpg
  10. camaro71/holland
    1,093
    48
    Aug 27, 2003
    The Netherlands
    Looking good! Time to finish this phucker :bowtie:
