1 3/4" Headers for AFR 210 Angle Plug in 81 Camaro
Discussion in 'High Performance Modifications' started by Sbrown1981, Dec 22, 2017.
  1. Sbrown1981
    Sbrown1981 New Member
    18
    Jan 1, 2016
    Stratford ontario
    Hi guys,
    I am in the process of building a new Dart Block based 427 SBC for my 81 Camaro. I will be using AFR 210 Race Ready Cylinder heads with angle plugs. Can anyone recommend from experience a 1 3/4" Full Length header that will fit well with the angle plugs?
    Thanks!
    Steve
  2. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    651
    19
    Aug 18, 2011
    Upstate New York
    For 9" deck height the Hooker Super Competition worked well in my 73. AFR exhaust ports are .100" higher position over stock for the 210 heads.
    Sbrown1981 likes this.
  3. BonzoHansen
    American racing headers
  4. 1980RS
    1980RS Veteran Member
    2,214
    141
    Jun 17, 2006
    MN
    Yup, the Hooker 1 3/4" worked well in my car when I had a SBC in it. Changing plugs was a breeze and it was much easier to get at the starter also.
  5. G72Zed
    G72Zed Veteran Member
    600
    75
    Sep 8, 2015
    I use the Hooker Super Competition ones #2117, fits both the Sportsman ll and Canfield heads well, both angle plug.
  6. buildinmy73
    buildinmy73 Veteran Member
    1,060
    8
    Oct 20, 2007
    Bernardston, MA
    To be honest those heads are a little small for a 427 sbc you should atleast get the 215cc or 220cc . Also i suggest you get a hold of Chris straub Straub @ camshafts to set you up with a camshaft that's matched to your car. i just went through this with my 427 . He will also tell you that the correct header size should actually be bigger than 1.75 primaries and closer to 1 7/8 " . But that would require a custom built set from Lemons 1500+.
  7. Sbrown1981
    18
    Jan 1, 2016
    Stratford ontario
    Thanks a lot for all the suggestions guys, I really appreciate it. I just don't want to get a set and find they don't work because with headers you are kind of stuck with them!
    Thanks a lot!
    Steve
  8. Goat
    1,813
    28
    Jun 7, 2001
    moncure, NC
    I had a stroked 396 sbc with those same afr heads. I used both the 1 3'4" Doug's headers and the Hooker Super Comp 1 3/4". Both of them worked fine with no fitment or spark plug issues. Actually, I think the angle plug heads were a breeze for replacing plugs...
  9. Sbrown1981
    18
    Jan 1, 2016
    Stratford ontario
    That is good to hear because a couple of the plugs by the AC box are a bit of a pain to get at right now! I have just put on an AC Delete plate also though so that will help too.
  10. Sbrown1981
    18
    Jan 1, 2016
    Stratford ontario
    I have been doing a lot of looking and am thinking of going with either the Dougs D324 1 3/4" Headers or Dynatech 740-29310 1 3/4" to 1 7/8" Stepped headers. is anyone running either of these headers in a Second Gen Camaro that could share some insight on how well they fit?
