“Real” Chrome pen
Discussion in 'Interior Restoration' started by 8pack, Nov 26, 2017.
  1. 74Z28GC3
    74Z28GC3 Veteran Member
    1,577
    22
    Sep 1, 2000
    North Pole, Alaska
    Ok Darren, I will purchase the 2mm one. Thanks
  2. Smokey15
    Smokey15 Veteran Member
    2,281
    935
    Aug 13, 2017
    I see a trip to Hobby Lobby in the near future. Thanks for the info.
  3. 70lt1z28
    2,630
    391
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Just ordered one of these to do the fine edging ring on the 70 steering wheel shroud. Has anybody tried the SEM low luster clear over top of it yet?
  4. 8pack
    2,448
    86
    Aug 29, 2007
    Pittsburgh, PA
    I used the SEM clear over a silver pen when I did mine. I think it is in my build thread. But, my bet is based on what I read you should let this stuff dry a good solid week or more if you have time before topcoating.
    To top the silver I did not tape it off. I sprayed the paint into a sheet of aluminum foil and let it puddle. I took a fine art brush and dipped it in the clear and then floated it over the top of the silver. If you do it just right it won't run or drip. You don't want the brush to touch the paint underneath it it will pull it into the clear. You want the clear to sit right on top so you need to keep reloading the brush.
    When I get to my test on my shifter surround I will try it. However, I don't think you want the low luster as it will pull the chrome. I think you want to try it with the gloss.....
    I love kicking off a good thread!
  5. 70lt1z28
    2,630
    391
    Oct 3, 1999
    Thanks for the update.
    Wasn't the dash edging and the horn shroud edging just kind of a matte silver originally? Every car I look at none of them are a high gloss chrome, but then none of them are brand new either. Maybe the faded fast from gloss to flat. I guess I am saying that maybe a little dulling will make it closer to original, which is what I am trying to achieve. If it turned out chrome that would be OK too. I don't really expect it to be like a true vacuum metalized chrome like the surrounds around the gauges.
    Blown Camaro likes this.
  6. Plater Tom
    Plater Tom Veteran Member
    1,355
    16
    Feb 2, 2003
    Mt Pleasant, Pa. USA
    I am pretty sure that Santa Claus will be bringing me one of those pens real soon. :)
  7. 70 Proof
    70 Proof Veteran Member
    453
    33
    Sep 28, 2014
    Southern Utah
    70Chev & 8pack
    Product Update-
    I received the "Liquid Chrome" 4mm pen a few days ago and tried it out today on a short section of the trim line around my inst cluster. 70Chev you were right. Its a very good product. I've tried two or three other silver pens in the past and this one is the most chrome looking of the bunch. Thanks for the tip.
  8. Blown Camaro
    Blown Camaro American by birth, drag racer by choice
    1,199
    139
    Dec 13, 2009
    Deltona, FL
    You are correct, and I used a matt silver pen on mine years ago and it was an exact match. You cannot tell where I stopped or started as I was just repairing places it had worn off.
  9. 70Chev
    70Chev Veteran Member
    238
    42
    Oct 21, 2012
    Brisbane, Australia
    Very cool. Glad it worked out for you.
