10-01-2007, 07:35:00 PM
#1
The Birdman of Carlisle, LGM
How Soon Do I Change My Oil (First Time)
I have about 10 driving miles on the car but it is the oil I put in it from the get-go. It has been started umpteen times and run for a 5-10 seconds (it was too loud to run it longer with open headers then).
I have a good K&N oil filter but my oil is getting dirty looking and smells a little like gas. After I fire it up and then check it it looks clear though.
Also, it doesn't smoke at all but it looks like the oil level on the dipstick dropped quite a bit since the last time I drove it.
I just got back from another ride!
10-01-2007, 07:53:19 PM
#2
I'm assuming the gasy smell is due to a rich condition at intial startup and the rings not being seated allowing some unburned gas to get into the crankcase. Gasoline will deteriorate/break down motor pretty quickly. Not only that, but it will also act as a "degreaser" inside your engine and oil won't stick to the metal surfaces, therefore you're lacking that protective "film" on critical moving parts. I'd say change it ASAP along with your filter.
-Andy
1979 Z/28 (better than cloned)
ΜOΛΩΝ ΛΑΒE
Proud NRA Lifetime Member
GeorgiaCarry.org Member
GeorgiaPacking.org Member
10-01-2007, 08:13:33 PM
#3
I think its 500 miles after a rebuild, and regular oil, not synthetic.
10-01-2007, 08:32:25 PM
#4
One at 500 miles and another at 2000 miles
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself.
--John Stewart Mill--
http://community.webshots.com/user/Pete0331
10-01-2007, 08:51:01 PM
#5
Did you change it after breaking in the cam? I have had machine shops tell me its good to get the break in lube out after cam run in.
10-01-2007, 09:03:13 PM
#6
Yep, you should have changed the oil right after the cam break in before you drive it, then again at 500 miles, then at normal intervals.
10-01-2007, 09:19:36 PM
#7
I knew I forgot something...
10-01-2007, 11:58:23 PM
#8
If it's a roller cam, he might not have bothered with the cam break in.
If it is, yeah you need to change it as soon as it's shut down after that 20-30 minute 2000+ RPM garage howl. The old moly disulfide (IIRC) stuff clogs the filter pretty quick.
I usually change the oil again in 50 miles, again at 200 miles, and again at 500 miles. After that, every 2000 miles until I get to about 10,000 total. After paying for a rebuild, the oil and filters seem awful cheap.
I'll get this thing put back together eventually!
10-02-2007, 02:18:04 AM
#9
thats the advice i was always given.
10-02-2007, 07:58:16 AM
#10
Thanks guys - I'll change it before I flog it again.
10-02-2007, 09:02:37 AM
#11
Yep, change after cam break in, then at 500 miles. I did my first one with a K & N filter, then the 500 miler using a better filter, a Mobil 1 which is what I normally use. I'll do the 2nd between 1000 and 2000 miles, then will switch to syn oil.
I'm just Mike
“From the hour the Pilgrims landed, to the present day, events, occurrences, and tendencies prove that to insure peace, security and happiness, the rifle and pistol are equally indispensable . . . the very atmosphere of firearms everywhere restrains evil interference - they deserve a place of honor with all that is good”
George Washington
10-02-2007, 09:37:38 AM
#12
Change it now, Change it again after a couple hundred more miles, then on to your normal change intervals.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
Originally Posted by Lowend
For the record I agree with Aces and hhott71
If the rear end grenades it blows your nuts off...
Originally Posted by Strange81Z
That's because we have more to give....ask any women who's been with a conservative and a liberal! LOL!
10-03-2007, 08:54:05 PM
#13
+1 Same thing I heard from 2 engine builders.
Dave Cozzi
1970RS Camaro.
Tons of "go fast goodies" but, still does not move.
10-03-2007, 09:17:16 PM
#14
Location: Striking fear and destroying the enemy from my borders
Ask Marv what he does for oil changes on NEW motors....lol....and how often.....
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America ' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in THIS country who no longer understand it.'
http://community.webshots.com/user/rscamaro73
Facebook - rscamaro73
I'm sometimes called Wayne
| Thread Tools |
| Display Modes |
Linear Mode
