Ecklers Camaro Parts and Accessories
Go Back   NastyZ28.com > Body & Chassis Restoration > Suspension, Brake & Wheel Topics
Thread Tools Rate Thread Display Modes
Old 09-20-2007, 08:45:16 PM   #1
TBART1970
TBART1970's Avatar
Chassis and suspension
Chassis and suspension almost done, will find out soon the new numbers, still a few things to sort out. Hopefully it will be good. What do you think?
TBART1970 is offline   Reply With Quote
Old 09-20-2007, 08:52:28 PM   #2
1981gMachine
1981gMachine's Avatar
Send a message via AIM to 1981gMachine Send a message via MSN to 1981gMachine
You build that yourself?
Edit. nvm I read you last post on the DSE. Also remember the issues you were having...
Present Setup:
355ci (300hp/375tq @ wheels), TH350 (shift kit) Hurst V-Matic2, 69camaro 12bolt, 3.55 richmonds, Moser axles, Traction Bars, Fatman Fab. C/A's, Poly C/A, Leaf Spring & Tranny Mount, Solid Motor Mount, 8-Point Roll Bar, QA1 Coil-Overs at all 4 Corners, TTII's F:15x7 R: 15x10, Goodyear GTII's F:215/65 R:275/60
Near Future:
Murdered Out Camaro, w/ a few lil mods
1981gMachine is offline   Reply With Quote
Old 09-20-2007, 08:55:19 PM   #3
TBART1970
TBART1970's Avatar
I did the new suspension, with help from SC&C and some ATS spindles. It was (ahem) some one else's chassis that will remain nameless as to not stir up any more controversy.
Old 09-20-2007, 09:00:46 PM   #4
1981gMachine
Oh ok, looks nice thou. Figure how much weight you saved over the stock frame?
Present Setup:
Near Future:
Old 09-20-2007, 09:14:54 PM   #5
Marks71BB
Marks71BB's Avatar
Send a message via ICQ to Marks71BB
I got some help from Mark at SC&C as well. Great guy!!
I just cleaned up the OEM frame and added QA-1 coil overs, tubular uppers from Mark, tubular lowers from GW and Wilwood brakes.
"America is at that awkward stage. It's too late to work within the system, but too early to shoot the bastards."
Marks71BB is online now   Reply With Quote
Looks Great at Car Shows !!
3 Styles to Choose From: 1970, 1977 or 1978 !!
$17 Shipped in USA or Canada. Easy Ordering !!
Old 09-20-2007, 09:57:51 PM   #6
KJZ28
KJZ28's Avatar
That is very nice...mine looks awful. Good Luck with that!
KJZ28 is offline   Reply With Quote
Old 09-20-2007, 10:02:01 PM   #7
3_z28camaro
3_z28camaro's Avatar
That's some very nice work!
1969 Camaro Z/28 clone (LS1/4L60E in waiting), 1971 RS Z/28 clone (C5 Corvette brakes, LT1/4L60E), 1972 RS, 1994 Z/28
Pink Toenails/Possum-Goat in '12
http://www.donkeyrescue.org/
3_z28camaro is offline   Reply With Quote
Old 09-21-2007, 06:52:45 AM   #8
John Wright
John Wright's Avatar
Send a message via AIM to John Wright
Lots of work in those few pictures....how many hours do you figure you have in all of that? Looks great, I know you bound to be anxious to try it all out.
John Wright is offline   Reply With Quote
Old 09-21-2007, 10:28:22 AM   #9
TBART1970
TBART1970's Avatar
It will be some time before it is on the road, not time to work on it. I have many hours in it, measuring and fabricating.If I knew it was going to be like this I would have used the stock chassis will all the goodies, but three years ago when I bought it there was nothing for our cars like there is now, plus I am a little smarter now that some have schooled me in geometry and torsional rigidity. I believe it saved about 200lbs. when I got it now it is a little heavier due to the added bracing.
thanks for the feed back.
Old 09-21-2007, 11:40:22 AM   #10
MadMatt
MadMatt's Avatar
Tbart, that is one of the nicest pieces of custom fab work i have seen for a second gen. What inspired you to do this? What application do you intend to use this for? Autocrossing? I bought all the global west goodies, and I only intended to clean up my stock subframe and reinforce some of the weak points. Any suggestions as to where to focus my attention?
Thanks... Again very nice!
MadMatt is offline   Reply With Quote
Old 09-21-2007, 02:05:58 PM   #11
jayb53guy
jayb53guy's Avatar
Send a message via Yahoo to jayb53guy
Awesome
jayb53guy is offline   Reply With Quote
Old 09-21-2007, 02:14:08 PM   #12
BLUE72CAMARO
BLUE72CAMARO's Avatar
Man that looks nice!!!
72 SS396 under restomodification.
500hp 468 w/t56 transmission
and way to much other stuff to list.
BLUE72CAMARO is online now   Reply With Quote
Old 09-21-2007, 09:09:23 PM   #13
TBART1970
TBART1970's Avatar
The stock factory chassis with aftermarket parts is hard to beat. I don't think there is much more to do than the control arms, better tires, correct alignment, performance box and I think the tall ball joint mod. Frame connectors are a must along with solid body mounts. ( I never fully researched the stock chassis, I should have.). The reason I went with this was for the wow factor mostly, I also made the assumption that the aftermarket chassis had better numbers than stock, the frame was definitely lighter than stock but very flimsy. I am far from an expert on this stuff but I learned the hard way.
thanks for the good feedback
-Tom
Old 09-22-2007, 06:28:00 AM   #14
Nate81camaro
Tom - looks good!
Mild 355, X Pipe & Violators, 3.73s, Eaton posi, Moser 30 spline.
Originally Posted by mmiler
You don't swap to a big block and then wonder about gas mileage, you put your foot in it and roast 'em down the street!!! Thats like turning down a hot sweet piece of a$$ because she wants you to buy her dinner first! YOU GOTTA PAY TO PLAY!!!
Nate81camaro is offline   Reply With Quote
Display Modes Rate This Thread
Rate This Thread:
Copyright © 1997 - 2010 M Squared Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
