Ecklers Camaro Parts and Accessories
Go Back   NastyZ28.com > Body & Chassis Restoration > Suspension, Brake & Wheel Topics
Thread Tools Rate Thread Display Modes
Old 09-18-2007, 09:25:14 PM   #1
Mwilson
S-10 steering box direct bolt in?
The pitman arm seems to have a 3" offset and mine on the car is strait?
Mwilson is offline   Reply With Quote
Looks Great at Car Shows !!
3 Styles to Choose From: 1970, 1977 or 1978 !!
$17 Shipped in USA or Canada. Easy Ordering !!
Old 09-19-2007, 09:50:53 AM   #2
MEAN_SBC
I'm about to make this swap as well, so I'd like to see a reply here too!
8.44 @ 171 1/4 mile
1284 RWHP @ 24psi
Tagged, Stickered, Insured street car on Radialz...
Brant
webmaster@amarilloracers.com
Turbo Build Link
MEAN_SBC is offline   Reply With Quote
Old 09-19-2007, 10:45:30 AM   #3
1981gMachine
1981gMachine's Avatar
Send a message via AIM to 1981gMachine Send a message via MSN to 1981gMachine
From what I've read over and over again, you use the stock S-10 manual box with your stock Camaro Pitman Arm. That's it
Present Setup:
355ci (300hp/375tq @ wheels), TH350 (shift kit) Hurst V-Matic2, 69camaro 12bolt, 3.55 richmonds, Moser axles, Traction Bars, Fatman Fab. C/A's, Poly C/A, Leaf Spring & Tranny Mount, Solid Motor Mount, 8-Point Roll Bar, QA1 Coil-Overs at all 4 Corners, TTII's F:15x7 R: 15x10, Goodyear GTII's F:215/65 R:275/60
Near Future:
Murdered Out Camaro, w/ a few lil mods
1981gMachine is offline   Reply With Quote
Old 09-19-2007, 08:22:29 PM   #4
ChevySean79
Send a message via AIM to ChevySean79
i did this swap i used a 89 s10 manual box and the stock 79 camaro pitman arm worked perfect
ChevySean79 is offline   Reply With Quote
Old 09-19-2007, 10:05:32 PM   #5
Cable Slacker
just did the swap on my 70 the only problem that arose is that the shaft on the s10 box is thinner than the box I removed. do I need a coupler from the s10 ??
Cable Slacker is offline   Reply With Quote
Old 09-19-2007, 11:36:33 PM   #6
rscamaro73
rscamaro73's Avatar
Location: ...standby...loading...do not turn off your computer...
By 'shaft' do you mean the threaded arm that the pitman arm is connected to ? I know what you're referring to if that's what you mean because I had that issue as well a long time ago.
If you stick to a 3rd gen unit....you'll get the same diameter shaft for the pitman arm. Then use the S-10 steering coupler (rag joint) if its for an early year car (76 or earlier - maybe up into early 77)....otherwise use the 'metric' coupler....
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America ' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in THIS country who no longer understand it.'
http://community.webshots.com/user/rscamaro73
I'm sometimes called Wayne
rscamaro73 is offline   Reply With Quote
Old 09-19-2007, 11:54:09 PM   #7
Cable Slacker
the shaft that attaches to the rag joint is to skinny to attach my existing rag joint. Do I need to change the rag joint and if so which one to buy thanks
Old 09-22-2007, 10:31:26 AM   #8
Skip Fix
There are two different S-10 boxes. The 525 box(also the most common replacement aftermarket box) uses a different pitman arm. I believe it is the 89 and later ones that use the 778 box. It is a direct swap , just did it on my 79. Rag joint a direct swap also,althoug I used Borgeson needle bearign joints and collapsable shaft.Also the early F body manual boxes use a specific pitman arm also, I think it is being repoped and on E bay some.
Skip Fix
1978 Trans Am 10.99@ 124 pump gas 455
1979 Camaro 383 soon to get a 500" Pontiac motor
1981 Trans Am 400,Turbo 301 on a stand
2004 GTO
1965 GTO BIG project
1964 Impala SS 409/470ci stroker project
Skip Fix is offline   Reply With Quote
Old 11-28-2007, 07:22:37 AM   #9
Mwilson
Is this the correct one?
http://www.autozone.com/R,APP853677/...ductDetail.htm
1977 CAMARO PROJECT
Old 11-28-2007, 07:50:14 AM   #10
John Wright
John Wright's Avatar
Send a message via AIM to John Wright
I'm curious of what the attraction is with these S-10 boxes, several people have done it, and I was just wondering what the advantages are of running these boxes.
At $310...you could add a couple bucks and get a brand new quick ratio AGR unit. Junk yard box is probably the way to go if you're looking to do the swap. Are you just looking to free up a belt from the motor?
John Wright is offline   Reply With Quote
Old 11-28-2007, 08:33:44 AM   #11
Mwilson
Originally Posted by John Wright
I'm curious of what the attraction is Are you just looking to free up a belt from the motor?
Thats it ditch ps pump big heavy box and eliminate a belt being driven by the motor
1977 CAMARO PROJECT
Old 11-28-2007, 08:58:34 AM   #12
gregh
gregh's Avatar
Send a message via Yahoo to gregh
Read this
This is the correct casting number manual box for the later model cars, I don't think it works for the 77 & prior camaros.
10.236@131.52mph with a 150 shot & 11.60@118mph NA
A 10 second street car, eh!
SBC 409, through the mufflers, on DOT radials, you know, like a street car should be.
gregh is offline   Reply With Quote
Old 11-28-2007, 08:59:25 AM   #13
John Wright
I Gotcha, I figured it was probably the extra belt tugging at the motor.
Old 11-28-2007, 01:45:21 PM   #14
Skip Fix
There are faster ratio 525 boxes out there but they take a custom pitman arm. The 778 boxes can reuse the PS one.
Skip Fix
2004 GTO
Old 11-28-2007, 08:55:46 PM   #15
kstripes
kstripes's Avatar
I was wondering the same thing. Because I drive a '90 S10 PU w/manual steering,5 spd ,4 cyl to work everyday. I like the way it turns but I don't think I enjoy it more than I used to enjoy my '80 camaro the steering just feels a little tighter but its a pain for parking.
kstripes is offline   Reply With Quote
Display Modes Rate This Thread
Rate This Thread:
Copyright © 1997 - 2010 M Squared Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
