Old 09-16-2007, 10:32:30 AM   #1
Todd80Z28
Anyone see the benefits of a pre-oiler?
Like many here, I don't seem to drive my car all that often anymore. It can sometimes sit for a few weeks between starts. One of my concerns with that is the bearings being dry, or drier, than they'd be after sitting for just a couple of days.
Has anyone ever tried anything like this?
http://www.smartsynthetics.com/produ...mk01-amk02.htm
I know the mains on the bottom end of my engine are down through a couple layers of material. It's only got 82k on it, and with a whopping 320hp, maybe, it's not like I'm brutalizing them. I'm left to wonder if it's the dry starts that are the problem.
Thoughts?
Todd
Todd80Z28 is online now   Reply With Quote
Old 09-16-2007, 11:26:19 AM   #2
Lowend
Lowend's Avatar
A buddy of mine who is an engineer did some research of these pre-oilers a few years back and found that they really don't have any effect. The pressure isn't high enough and not well directed enough to really do anything to float the crank.
That was on a Canton system though
“Realists do not fear the results of their study.”
- Fyodor Dostoyevsky
  • This makes sense. I'm agreeing with Lowend,. - Shawn 1/27/2011
  • Lowend sit down for a minute because I'm going to agree with you on this point - Knuckle Dragger 12/14/2012
  • I (gulp) very much agree with this - 69LM1 1/12/2013
Come make a difference at Kiva!
Lowend is offline   Reply With Quote
Old 09-16-2007, 12:00:22 PM   #3
camertom
Not needed at all in an automotive engine. They are needed in 2500 hp 45 litre diesels with huge volume capacity oiling circuits but in a V-8? Someone wants your money more than you do. The bearings are not "drying out".
74 Camaro Sport Coupe
406 w/AFRs T350 3000stall 4.10 gears, naturally aspirated
11.56 / 114.92 w Hedders open and 11.82 / 113.01 thru the mufflers
Don't own a trailer, so I drive it to the track
Friday nite drags volunteer
camertom is offline   Reply With Quote
Old 09-16-2007, 02:46:10 PM   #4
rchydzik
rchydzik's Avatar
What leads you to think your bearings are worn? If they are, I am just curious as to what type of motor oil you have been using. I think a block heater might be more effective, especially if you are starting it on cool mornings.
76 LT
02 Z28
rchydzik is offline   Reply With Quote
Old 09-16-2007, 03:36:37 PM   #5
Todd80Z28
They were worn the last time I had the main caps off, just to take a peak. That was around Xmas 2001. I was down into the 3rd layer of material. That, and after three tries, I cannot get the rear main seal to seal up. A respected builder in FL told me top reason for that, assuming correct install, was a worn rear main bearing.
I didn't/don't really care enough about the engine that's in the car now (which is the factory original LM1 bottom end) to do a full rebuild at that time. I'm thinking more about the next build, and protecting it.
Old 09-17-2007, 02:46:12 PM   #6
onovakind67
We use an accumulator in our road race motors. It keeps the oil pressure more constant under severe road conditions, and can be used as a pre-oiler if you close it off when the oil pressure is high.
onovakind67 is offline   Reply With Quote
