Old 08-17-2005, 10:00:00 PM   #1
mrsbojigger
engine offset
Installing LS1 engine into '80 Camaro. I have measured from side to side with engine in place. The engine sets 1" to the right (passenger side). Is this correct? Is this to factory specs? My mechanic doesn't know. I know my Hudson has an offset engine.
Chaz
mrsbojigger is offline   Reply With Quote
Old 08-17-2005, 10:34:00 PM   #2
retorq
Yes, I ran into the same thing when I cut a 16 inch hole in the center my hood for the air cleaner!! I ended up having to cut it to 18 to get it to look right. I was told it was normal and due to the steering linkage.
The first digital hijinx I designed was quite naturally perfect. It was a work of art. Flawless. Sublime. A triumph only equaled by its monumental failure.
retorq is offline   Reply With Quote
Old 08-18-2005, 12:02:00 AM   #3
80'427
I will tell you after changing plugs in my 99 firebird tonight the factory LS1 sits closer to the pass side by at least a inch if not more.
80'427 is offline   Reply With Quote
Old 08-18-2005, 09:14:00 AM   #4
mrsbojigger
Thanks Guys,
Chaz
Old 08-19-2005, 12:00:00 AM   #5
dgwar
I had the same problem when I put my Big Block in...turns out I missed the hole on the motor mount. bolt went through the outside mounting holes fine and missed the inside mount hole.
I jacked that side back up and slid the inside mount back in place installed the bolt and now it sets level.
1981 Camaro Coupe
402 auto.
http://www.home.earthlink.net/~dgwar/
dgwar is offline   Reply With Quote
