Go Back   NastyZ28.com > Drivetrain & Performance > High Performance Modifications
Old 04-07-2007, 07:26:02 PM   #1
badcompany
92-96 LT1 aluminum heads
Anyone have any experience with these heads?Found a pair fairly cheap local.Would they a good head for a street motor?
badcompany is offline   Reply With Quote
Old 04-07-2007, 07:34:07 PM   #2
LTjames
Those heads are off of the gen II small block...wont work on an older SBC. But if you have an LT1...thats a different story.
James
Turbocharged 78 Z28 4 speed SOLD
1981 Turbo trans am WS6
1976 Datsun 280Z with an RB25DET
Elzie - You've got some good looking wood there, lowend
LTjames is offline   Reply With Quote
Old 04-07-2007, 07:40:20 PM   #3
badcompany
Are Vortech heads Generation II?
Old 04-07-2007, 08:00:11 PM   #4
cmonson
cmonson's Avatar
vortec heads bolt right on with a new intake. I highy suggest them. Easiest 40HP there is for the money.
read this:
http://www.nastyz28.com/forum/showthread.php?t=56505
cmonson is online now   Reply With Quote
Old 04-07-2007, 08:10:16 PM   #5
Damon
While there are similarities between the LT1/4 heads and later Vortec heads, they are totally different animals. All LT1/4 heads are designed for reverse cooling- you can't just bolt them on an earlier engine and go. Also, the intake bolt pattern is completely different from all other SBC intake bolt patterns- it's not like a Vortec, not like 87-up heads and not like 86-down heads. Modifying them to work on earlier engines has been done but it's probably not worth the hassle.
As GM refers to their engine families, the Vortec engines are technically modified and updated "Gen I" small blocks, even though they came out after the "Gen II" LT1/4 engines. There's nothing much in a Vortec motor, aside from those killer Vortec heads, that didn't exist for 10+ years before on other factory small blocks- roller cams, one piece rear main seals, centerbolt valve covers, sequential fuel injection, serpentine accessory drive systems- nothing much new under the sun. Crazy, ain't it?
Vortec heads were used on late 90s truck engines before they went to the LSx-based engines. They use standard coolant flow and will bolt on to an eariler block with no problems. They do use their own vortec-specific intake bolt pattern but aftermarket carburetor intakes for them are easily obtained from all the usual manufacturers.
1990 454SS pickup. Original "tow truck motor" 454 upgraded to something a little more "aggressive." Seems pretty stout but the fuel bill is nuts.
78 Malibu. Inherited with only 35K on the odo! Mild 383 with Weiand 142 blower on top. Mid 12s appears to be the best it's gonna do on street rubber. Runs so good I may never drive it again.
"Last remaining QJet tuner on planet Earth!"
Damon is offline   Reply With Quote
