Old 05-11-2005, 10:23:00 AM   #1
Philly78LT
Upper radiator hose sucking flat, please help...
Hey guys we replaced the radiator cap and the upper radiator hose and the problem of the hose sucking flat stopped and the car was running at normal temp for awhile.
Now its back to getting too hot even just idling for awhile, not sure if the radiator hose stopped getting flat because the newer one was stiffer or if that problem is solved. But im going to guess the overheating problem is the same as before.
Any ideas why it might do that? With the radiator cap replaced all I can think of is the water pump, anyone have past experience with this problem?
--Grant
CURRENTLY IN THE DRIVEWAY:
1978 Camaro Type BERLINETTA
1972 Nova Type SS Clone
2002 Honda CBR 600F4 Type Fuel Injected
Philly78LT is offline   Reply With Quote
Old 05-11-2005, 11:50:00 AM   #2
retorq
Did you check and verify that the thermostat opens at temp?? Might be bad. Also start it witht he cap off, you should be able to see the coolant move. You should be able to stick your finger in and feel the water moving past your finger.
The top hose was going flat?? The top hose is the return line, that shouldn't compress flat.
[This message has been edited by retorq (edited May 11, 2005).]
The first digital hijinx I designed was quite naturally perfect. It was a work of art. Flawless. Sublime. A triumph only equaled by its monumental failure.
retorq is offline   Reply With Quote
Old 05-11-2005, 11:50:00 AM   #3
Marv D
Marv D's Avatar
Normal early sbc flow is in the bottom hose, out the top of the motor. This sounds suspiciously like you have the water pump turning the wrong direction (for the pump you have) Do you have standard V-belts, serpentine belt, or some aftermarket serpentine belt setup?
Marv D is offline   Reply With Quote
Old 05-11-2005, 01:30:00 PM   #4
John Wright
John Wright's Avatar
Also I'll add to use a bottom hose with wire inside to help prevent it from collapsing.
John Wright
Life is like a roll of toilet paper. The closer it gets to the end, the faster it goes.
John Wright is offline   Reply With Quote
Old 05-11-2005, 01:47:00 PM   #5
Philly78LT
The flow seemed to be moving quite well the last time we checked it (after initially replacing the upper hose) we also replaced the T-Stat at the same time, it seems hard to believe that a brand new T-stat went bad though it could be, when I get home I will double check the flow through the radiator make sure its still moving well. Also its a regular belt system nothing special.
--Grant
Old 05-11-2005, 03:00:00 PM   #6
ZZ430
Does it have an operational recovery system?
Sounds like it either has the wrong cap or needs a recovery container that's vented to atmosphere.
My Camaros
ZZ430 is offline   Reply With Quote
Old 05-12-2005, 11:32:00 AM   #7
sawyer61
My top hose went flat while I was setting up my electric fan and the temperature got to high, no problems after it was set. I don't know what the temp was when it happened, I just got the temp gage working, I did change the thermostat but I don't know if it was a problem or a normal reaction if it gets too hot?
79Z Made with tools - Not chop sticks
sawyer61 is offline   Reply With Quote
Old 05-12-2005, 06:30:00 PM   #8
CamaroMan79
CamaroMan79's Avatar
<font face="Arial,Verdana" size="2">Originally posted by John Wright:
</font>
I was told by an engine builder that the only hoses with springs in them are the cheap ones. he said Gates and the better brand hoses dont have the spring in them because they are of better quality. Ther last 2 bottom hoses ive boguht have been gates and have had no springs in them.
1978 Z28: forged roller cam 383 stroker, AFR Heads, AED double pumper
CamaroMan79 is online now   Reply With Quote
Old 05-12-2005, 09:54:00 PM   #9
Tokyo Torquer3
same things was happening to me..only sucked flat when the engine was shut off and cooled
found out that the vent tube from my recovory tank was blocked with a screw. Took out the screw that was stuck in the tube so it could vent and it didnt do it anymore
1973 RS Z28: Littlefield race series 6-71 supercharger on a 355 w/ AFR 195 heads, 12-14 lbs boost, 7.6:1 static compression, CompCams hydraulic roller (276/288 advertised, 224/236 @.050 duration, .510/.527 lift w/ 1.52 rockers on a 113 lobe separation), AFR Hydra-Rev kit, Eagle 4340 Forged Steel crankshaft, ARP studded bottom end, Eagle ESP H-beam rods, TRW forged reverse dome pistons, Comp Pro-Magnum 1.52 roller rockers with 7/16 studs, twin 750 Edelbrock carbs, 1&3/4 inch Hooker Super Comps, 3" dual exhaust with cross over pipe. MSD 6AL ignition & Pro-billet distributor, Tremec TKO-500 5-speed, Moser 12 bolt with Eaton posi, 33 spline axles & 3.42 gears.
1973 RS Z28: 401ci Dart Little M, Littlefield 8-71 supercharger @14lbs boost, Callies Magnum crankshaft, Lunati Pro-Mod rods, JE pistons, 7.8:1 compression, AFR 227 Comp heads, T&D 1.6 shaft rockers. Reed solid FT cam (240/250@.050, .523/.542 lift, 112 LSA), QFT 750 carbs, Lemons headers, Mezier mechanical water pump, Tremec TKO-500 5-speed, Moser 12 bolt, 33 spline axles & 3.42 gears.
Tokyo Torquer3 is offline   Reply With Quote
