02-28-2007, 11:30:48 AM
#1
Please help troubleshoot my ignition...
Hey everyone...I need some help...All of the sudden the engine wont crank with the key...
So to get up to speed...
We put the motor in...no trouble hooking up the wires on the starter...I double checked the connections...New battery...It cranked a couple times and then stopped working...The dash lights come on with the key but it wont crank...The dash and headlights do not dim when I try to crank it...The engine will crank and run when I jump the starter with a screwdriver...Is there a fuseable link or fuse somewhere to look for?I havent tried anything,I just moved to something else for now...
02-28-2007, 12:17:30 PM
#2
try ignition switch there cheap and not hard to put in also check the battery first
02-28-2007, 12:23:33 PM
#3
I would look at the fusible link going to the starter.
- Mike -
Some people work to make a living while others vote to make a living.
Can I join the GFB Fan Club?
Originally Posted by BonzoHansen
You are cruising for a banning! LOL
02-28-2007, 12:51:38 PM
#4
The fuseable link is the first thing I would check.
If it's not broken, fix it!
Marks71BB Great job!! she should be nice and stiff now!
Marks71BB Comes inna five gallon pail for the really big pull jobs
Upstanding member of E.V.A.L
(Enemies of Vacuum Advancement League)
02-28-2007, 02:36:37 PM
#5
The ignition switch is new and how do I check the fuseable link...If its bad how is it replaced? I do have the steering wheel off to replace the switch...It cranked with the key a lot...Then it just stopped...How about a neutral safety switch?I did try it while moving through the gears...Its an automatic...
Does it tell you anything because I can jump the starter with a screwdriver?
02-28-2007, 03:16:32 PM
#6
Do you have a test light or a volt meter ?. If so you can use those tools to trace the problem down.
Check this too but you may have lost power at the bulkhead connector.
Even new things can go bad but by using a basic tool like a test light or a meter you can see where you have power and where you don't. Ideally use a meter instead of a test light just to get in the habit. While checking voltages like on the starter solenoid a test light will work you don't want to use a test light on some other circuits as they can draw too much power and possibly damage things.
It's possible too maybe the shifter's nuetral safety switch is keeping power from passing through it.
Jim
02-28-2007, 03:28:43 PM
#7
You cooked your starter.
02-28-2007, 09:59:44 PM
#8
No it still cranks when you jump the starter with a screwdriver...I didnt mean that I cranked it until I smoked it...
So we used a meter on the positive side of the starter and had 12.39 volts and on the other wire zero until we turned the key to the start location and then we had 12.39 again...To me this says the neutral safety switch is ok,the ignition switch is ok,the fuseable link is ok...So did the starter solenoid take a poop?
03-01-2007, 01:15:11 AM
#9
Prolly.
03-01-2007, 07:15:29 AM
#10
I'd say check the solenoid (because you said the starter cranks when you jump it), then work your way back to the ignition. Between the good (starter) and the bad (the key) is the ugly (the problem).
Ev
Trust me...you don't have to see it to be able to use it. - cam80
I've been trying to get the hummers in my yard, but no luck. - spoonLT1355
Levi, I can understand.....buzzers would be annoying on a car with tube doors - John Wright
ugly chicks need lovin too - Lammy
NW Lifetime Member of GFB Fan Club.
03-01-2007, 08:11:46 AM
#11
Do ya get power @ the wire when cranking it with the key???
They all should've had Cowl hoods ......
Scott
03-01-2007, 09:21:46 AM
#12
Take a poop??........do we really need such vulgar language on this site???? sheeesh  LOL
03-01-2007, 09:49:33 AM
#13
SoCal Team Mom for Life / Moderator
You say it's a new switch? I'd check the adjustment, it sounds like it slid down the coluum a bit.
If it was the fusable link you wouldn't have lights.
"Nothing comes from talkers but sound
We can talk all we want to
but the world still goes around and round"
03-01-2007, 11:27:55 AM
#14
It isn't likey the solenoid is bad. The GM solenoid mounted on the starter is what engages the starter drive in the flywheel, and it works that way even if you have to short power to the starter with a screwdriver. With a bad solenoid, you won't likely be able to start it with a screwdriver either.
You need to look more at the wiring from the battery to the solenoid and starter. Jump across the neutral safety switch first. If that doesn't help, then look at the rest of the wiring.
03-01-2007, 11:37:49 AM
#15
Yes power when key in start position...
Um,Sorry...Excuse my French..lol.
Would it be the ignition switch when I get power to the starter?
Thanks guys for hanging in there with me...
| Thread Tools |
| Display Modes |
Linear Mode
