Go Back   NastyZ28.com > Body & Chassis Restoration > Interior Restoration
Old 02-10-2007, 11:20:41 PM   #1
CamaroMan79
CamaroMan79's Avatar
polishing aluminum bezel
What can I use to remove some mild scratches from an aluminum gauge bezel? Aluminum polish?
1978 Z28: 383 stroker; Scat forged crank and rods, SRP pistons, Comp Cams roller valvetrain, AFR 195 heads, SMI Quadrajet, air-gap intake, 1 3/4" headers, th400 trans
CamaroMan79 is offline   Reply With Quote
Old 02-11-2007, 12:10:26 AM   #2
1981gMachine
1981gMachine's Avatar
polish wont do anything but polish it
try fine sand paper, like 2000 grit or finer then polish it. The only thing is you have to sand in one direction. If the 2000 doesn't seem to be working go a lil courser then work your way back up to 2000.
I sanded mine starting from 400 grit to 2000 on a black and decker mouse. Used spray glue to hold the paper to a foam pad. Came out looking good.
Present Setup:
355ci (300hp/375tq @ wheels), TH350 (shift kit) Hurst V-Matic2, 69camaro 12bolt, 3.55 richmonds, Moser axles, Traction Bars, Fatman Fab. C/A's, Poly C/A, Leaf Spring & Tranny Mount, Solid Motor Mount, 8-Point Roll Bar, QA1 Coil-Overs at all 4 Corners, TTII's F:15x7 R: 15x10, Goodyear GTII's F:215/65 R:275/60
Near Future:
Murdered Out Camaro, w/ a few lil mods
1981gMachine is offline   Reply With Quote
Old 02-11-2007, 12:28:49 PM   #3
77camnut
I sanded mine like 81'gmach did. Then I used a mothers power ball to finish it off then cleared it. looks like a mirror.
77camnut is offline   Reply With Quote
Old 02-11-2007, 09:35:02 PM   #4
THOMAS81Z
good advice i am doing mine rite now
THOMAS81Z is offline   Reply With Quote
