Old 01-12-2005, 09:00:00 PM   #1
79camaro97
97 camaro engine and a 79 camaro
Glad I found a 2nd gen F-body board. I recently bought a 79 camaro that I'm picking up tomorrow that has a 97 camaro engine coming with it on the side and not in the car. I'm used to thirdgen camaros. Anyone here know of anyplace I can find info on doing the transplant or otherwise have some advice to help me out?
There is always going to be work, but you only have so much time to play.
79camaro97 is offline   Reply With Quote
Old 01-12-2005, 09:08:00 PM   #2
theflash
theflash's Avatar
I'm sure you can find a lot of info here. Welcome to your new addiction
Old 01-13-2005, 09:47:00 PM   #3
ULTM8Z
I believe the 97's still had the LT1's, correct? If so, go to my website (in my sig) and click on the EFI swapper's guide. Although it deals mainly with the L98 third gen engine, it does touch on LT1 stuff, and for the most part, the swap involves the same kind of work. You only need to interpolate some of the info to make it applicable to the LT1. Good luck.
And theflash is right. Welcome to your new addiction indeed! MUWAHAHAAHHAHAHAH!!!!!
Pro-Touring 71
1996 LT4 Corvette Wheels are 17x8.5 front, 17x9.5 rear
Wheel adapters are 2.0" front, 2.5" rear
Baer Brakes four wheel discs
Fuel Injected ZZ4, custom burned EPROM, AFR heads, TPIS Mini-Ram intake,
Comp Camshaft, TH700R4 Transmission.
God Bless the USA
Project Photos on ULTM8Z project photo album
See me in Chevy High Performance
ULTM8Z Website
ULTM8Z is offline   Reply With Quote
Old 01-14-2005, 12:58:00 PM   #4
73454
Posts: n/a
It will fit. The engine still had the same bellhousing pattern and engine mount pattern. You will have to deal with an Opti-Spark, but it's do-able. Get the wiring harness and computer if you can. It will make your life easier. It is an OBD-II system so you will need to do modifications to allow for the catalytic converter(s) and all 4 oxygen sensors. There will be one on each downpipe, one before the cat, and one after the cat.
Old 01-14-2005, 04:51:00 PM   #5
El Guapo
<font face="Arial,Verdana" size="2">Originally posted by ULTM8Z:
</font>
Dude! Interpolate??? I'm sorry but we don't speak French here -
El Guapo is offline   Reply With Quote
Old 01-15-2005, 12:26:00 AM   #6
79camaro97
Thanks for the help guys. My buddy started on getting everything together and done before I even got to see the thing...hope he didn't screw anything I wanted up. Anyway, yes, another camaro addiction. My fiancee is finally realizing it will never end.
Old 01-16-2005, 10:35:00 PM   #7
Air_Adam
Go to www.thirdgen.org theres lots of LT1 ('93-97 Z28/Formula/Trans Am) swap info there. Its all for 3rdgen Camaros and Firebirds, but 99% of the stuff still applies to 2ndgen Camaros just the same.
Spandex is a privelige, not a right!
Air_Adam is offline   Reply With Quote
Old 01-17-2005, 11:06:00 PM   #8
79camaro97
I've been going to that site for a while as RedTtop5spd. I commonly hang out in the v6 forum.
