12-28-2006, 11:17:11 PM
#1
Earls braided lines bleed fuel vapor?
So I'm putting my gas analyzer to use and am now able to truly pinpoint the source of that pesky fuel odor that I'm stuck with.
http://www.nastyz28.com/forum/showthread.php?t=69660
It's definitely the braided lines that I"m using for supply/return. All up and down the lines, when I put the sniffer to them, the HC's shoot up to 40-50 ppm compared to 0-2 ppm for normal air and around the rest of the engine compartment.
WHen I run the engine, I see absolutely no signs of liquid fuel leaking from anywhere along the fuel lines (and at 40 psi, any leak would be readily apparent). So what's the deal? Are the braided lines just porous enough to leak fuel vapors but not liquid fuel itself?
Has anyone heard of this phenomenon with braided lines? Do I need to switch to steel lines now?
12-28-2006, 11:33:08 PM
#3
SoCal Team Mom for Life / Moderator
I'm living with the smell for now considering the cost to replace it all. Damn.
Good find, you know next time the car is at the shop I'm going to run the smog sniffer over the hose route.
www.jakesperformance.com High performance automotive solutions based on real world experience; a welcome change in the copy and paste world of internet experts.
POS71RS is a gunky
Wheel Vintiques = Horrible customer service.
12-28-2006, 11:35:48 PM
#4
wow that's crazy... you never hear about this kinda stuff from the magazines! God bless the internet.. and especially nastyz28
Arte et Marte
http://www.youtube.com/watch?v=opQbd0bvbPw#GU5U2spHI_4
Now has ZZ4 short block, wiseco 10:1 forged under brodix IK200s w/ 670 street avenger, 1 3/4 hooker super comps, pypes X 2.5" Pro-V, 200-4R, quicksilver shifter, 3.73 w/ posi. Shootin for 12s.
12-28-2006, 11:40:49 PM
#6
Considering Mrs. ULTM8Z won't even go into the garage because it smells so bad (and always worries about me when I do), I don't think I'll have a problem selling this solution to her.
12-28-2006, 11:47:27 PM
#7
Thanks for the heads up. Something to keep in mind when I get to building my fuel delivery system.
Mark
"America is at that awkward stage. It's too late to work within the system, but too early to shoot the bastards."
12-28-2006, 11:48:37 PM
#8
BANNED
I'm happy that you've found and documented your fuel leak...
12-28-2006, 11:53:08 PM
#9
Originally Posted by ULTM8Z
Hmmm... apparently this teflon-lined hose might do the trick.
Do they use the same fittings as the braided line?
POS71RS is a gunky
12-28-2006, 11:56:50 PM
#10
of course not Dave... who are you kidding?? where would be the money in that?
12-28-2006, 11:59:39 PM
#11
Moderator
braided AN fuel line is nothing more than rubber fuel hose wrapped inside a metal braided jacket .so if they're leaking it's because the hose is old and brittle .the only other place i would think it would be leaking is from poor assembly of the fitting onto the hose . i've never heard of this before and have been around alot of race cars using braided line
old school / day2
engine
my camaro
open headers
thru the mufflers
12-29-2006, 12:11:41 AM
#12
If it were a bad connection, the HC spike would be localized to that connection. But for the HC readings to be relatively constand along the entire length of BOTH supply and return lines indicates an apparent uniform degradation or a porosity that's susceptible to local fuel additives around here. My readings in conjunction with what I've just read on the internet have convinced me that the lines themselves are the culprit.
12-29-2006, 12:13:23 AM
#13
Unfortunately, this "Speed-Flex" hose requires Speed-Flex fittings.  Typical...
Looks Great at Car Shows !!
3 Styles to Choose From: 1970, 1977 or 1978 !!
$17 Shipped in USA or Canada. Easy Ordering !!
12-29-2006, 08:16:58 AM
#14
Have you ever thought about a career in semiconductor equipment troubleshooting?  And, would you like to live in Northern VA?
Nice work! I would never have considered that.
12-29-2006, 10:07:55 AM
#15
Would the problem exist with a carb and stock fuel pump?
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
