Old 01-01-2005, 11:36:00 PM   #1
CA72RS
Big block "peanut port" and oval port the same?
Are big block "peanut port" heads and oval port heads the same? Are all oval port heads the same?
1972 Rally Sport - 90% stock. Mild 350 with 3 Speed manual. Soon will have 454.
1967 Chevy C10 Truck - 90% stock. Fleetside longbed. Soon will have 454. Turbo 400. "Armstrong" steering (manual steering)
CA72RS is offline   Reply With Quote
Old 01-02-2005, 12:26:00 AM   #2
jakeshoe
jakeshoe's Avatar
No they are not the same.
Peanut port refers to the very small "round" ports used on late 70-mid 90's motors.
They are great for their intended usage, and can actually work well on a mild street BBC.
This photo shows the difference in a peanut port vs. an oval gasket.
This is an oval head:
www.jakesperformance.com
4L80Experts and Performance GM Automatic Transmissions.
Check out www.race-trans-tech.com
jakeshoe is offline   Reply With Quote
Old 01-02-2005, 12:35:00 AM   #3
jakeshoe
jakeshoe's Avatar
Ovals again:
Rectangular ports:
Note the closed chambers of the rectangular port heads...
Old 01-02-2005, 12:43:00 AM   #4
jakeshoe
jakeshoe's Avatar
Semi-closed chambers:
Open chambers:
BBC Vortecs:
Old 01-02-2005, 02:43:00 PM   #5
CA72RS
Thanks for the great info. I'm pretty sure I have peanut port heads. Now I'm concerned if I get an Edelbrock intake for oval ports, the peanut ports will be smaller than the intake's ports, leaving a 'step' which will cause restriction.
Maybe I should just run the matching quad jet manifold until I upgrade the heads.
Old 01-03-2005, 03:15:00 AM   #6
badazz81z28
BANNED
<font face="Arial,Verdana" size="2">Originally posted by CA72RS:
</font>
Someone go ahead and correct me if Im wrong. Leaving the stock manifold on/unmatched ports on a edelbrock. I dont think there would be much a differnce in comparison.
I would think a edelbrock unmatched would be better than a stocker match cast iron intake. what you all think?
badazz81z28 is offline   Reply With Quote
Old 01-03-2005, 12:02:00 PM   #7
jakeshoe
jakeshoe's Avatar
The mismatch is not a problem. The "step" is not detrimental to performance.
The larger plenum and runner volume of the oval intake will better feed the motor.
Old 01-03-2005, 09:31:00 PM   #8
pdq67
BANNED
Imho, the easiest way to tell to me is if they are wider then they are tall they are PP heads!
And if they are taller then they are wide, then they are large ovals!
And everybody know's how big and rectangular, rect's are...
And I'm not even going ta get inta the "ROVAL" deal that's like a 2/3rds tall, rect port...
pdq67
pdq67 is offline   Reply With Quote
