Ecklers Camaro Parts and Accessories
Thread Tools Rate Thread Display Modes
Old 11-30-2006, 10:48:47 PM   #1
75camaro03
Send a message via AIM to 75camaro03
rolling fender lips
i was wondering if someone could explain to me what this means and how to do it. thanks LA
TO ENDURE PAIN IS TO EXCELL
75camaro03 is online now   Reply With Quote
Old 12-18-2006, 03:40:41 PM   #2
75camaro03
TTT for any info.....also if this is the wrong section just let me know. thanks
Old 12-18-2006, 03:52:05 PM   #3
hardline_42
hardline_42's Avatar
Send a message via AIM to hardline_42
The fender lip refers to the 1/2" - 1" of sheet metal that bends in 90* at the bottom edge of the fender. Rolling the fender lip means bending the lip up ~180* flat against the inside of the fender. This can be done with a special dedicated tool or with a baseball bat wedged between the tire and the fender. The point of rolling the lip is to gain that extra 1/2" to an inch of clearance for wider tires.
'81 Sport Coupe 229 V6 - Junked
'93 Z28 5.7L LT1 - Parted
"Is that a rat? No, it's just a really fat mouse."
hardline_42 is offline   Reply With Quote
Old 12-18-2006, 07:06:38 PM   #4
75camaro03
ok cool....where can i get the special tool to do this.... im going to need it on my 4th gen so i can fit 315 on the back..the 2nd gen is going to get a mini tub so m not to worried about that one
Old 12-18-2006, 09:05:52 PM   #5
1WILDZ
Send a message via AIM to 1WILDZ Send a message via Yahoo to 1WILDZ
I went with the Louisville Slugger route. It worked real nice, not sure if the tool was around when I rolled mine.
DOUG
2009 2nd place Camaro Nationals
2007 3rd place Camaro Nationals
1979 Z28 360ci, 11:1 comp, Comp Cams Extreme energy hyd roller, turbo 400 reverse manual valve body, 10 bolt rear Eaton posi 3.90 gears, Moser axles
http://www.cardomain.com/ride/456765
1WILDZ is offline   Reply With Quote
Old 12-18-2006, 10:00:39 PM   #6
no-nitro
no-nitro's Avatar
there is someone on ebay that rents them for 4-5 days at a time if you win the bid.
this is what i hear atleast.
you will have to do a search on it.
no-nitro is offline   Reply With Quote
Old 12-18-2006, 10:09:07 PM   #7
gregh
gregh's Avatar
Send a message via Yahoo to gregh
I phoned around to the local import shops until I found one that had this tool for rental. I think it was $100 for the day & so I had 3 other people come by & we did 4 cars in a few hours, cost us $25 each.
It worked OK but the tool was rather cheaply built & I had to weld it back together even before we started using it.
10.236@131.52mph with a 150 shot & 11.60@118mph NA
A 10 second street car, eh!
SBC 409, through the mufflers, on DOT radials, you know, like a street car should be.
gregh is offline   Reply With Quote
Old 02-08-2007, 07:52:49 PM   #8
1981gMachine
1981gMachine's Avatar
Send a message via AIM to 1981gMachine Send a message via MSN to 1981gMachine
Does this rolling the lip work on the front with inner fenders in the car? If so will a bat be able to do the front?
Present Setup:
355ci (300hp/375tq @ wheels), TH350 (shift kit) Hurst V-Matic2, 69camaro 12bolt, 3.55 richmonds, Moser axles, Traction Bars, Fatman Fab. C/A's, Poly C/A, Leaf Spring & Tranny Mount, Solid Motor Mount, 8-Point Roll Bar, QA1 Coil-Overs at all 4 Corners, TTII's F:15x7 R: 15x10, Goodyear GTII's F:215/65 R:275/60
Near Future:
Murdered Out Camaro, w/ a few lil mods
1981gMachine is offline   Reply With Quote
Looks Great at Car Shows !!
3 Styles to Choose From: 1970, 1977 or 1978 !!
$17 Shipped in USA or Canada. Easy Ordering !!
Old 02-09-2007, 01:42:05 AM   #9
POS71RS
POS71RS's Avatar
Send a message via AIM to POS71RS Send a message via Yahoo to POS71RS
Even if you plan on tubbing the rear, it 'might' still be a good idea to roll the lips, so that you can set the tire closest to the quarter, so it looks better. I personally cant stand when the tire sits far behind the quarter skin.
Gmach, you cant roll the fronts with that tool, or a bat. The inner fender wont stretch to accomodate roller the fender lip up.
Also, if you somehow manage to do this, MAKE SURE THE BOLTS ARE OUT OF THE FENDER TO INNER FENDER. Otherwise, the bolts will push outward dimples into the fender body line.
The Sig of Shame:
Aceshigh:...On my laptop nothing yet. I keep wackin it...
67lemanster:...I just opened your package and ate it all...
msex67lemanster: its so big its hurting my eyes. can you make it smaller?
Chevrolaine Ditto, I'll take 10" any day!
70ish camaro..it actually got hard this time which made me happy..
Knuckle Dragger..I'd like to knuckle that cock..
Project Progress
Old 02-11-2007, 12:10:49 AM   #10
FAST79Z28
Can someone post some pics on what it actually looks like with the rears rolled?
FAST79Z28 is offline   Reply With Quote
Old 02-11-2007, 09:02:24 PM   #11
Xelerator
The photos below show my body on a rotisserie, alot easier this way. I used a block on the outside with my jack pushing up while I slowly hammered with a rubber mallet untill I got what you see.
Attachment 3325
Attachment 3326
1973 Camaro Type PT "Pro-Tour theme"
1985 Camaro IROC Silver TPI
1997 LT4 #18/100 30th SS
2002 Z7D,Brickyard 400 Festival car
My Toys
Xelerator is offline   Reply With Quote
Display Modes Rate This Thread
Rate This Thread:
Copyright © 1997 - 2010 M Squared Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
