Old 11-05-2006, 07:36:47 PM   #1
JerryL
JerryL's Avatar
Dual snorkel air cleaner
Will a dual snorkel air cleaner from an early Z28 (70-74) fit a 79Z with a 4-bbl holley? Thought I read a thread awhile ago that said it would not clear the HEI distributer.
JerryL is offline   Reply With Quote
Old 11-05-2006, 07:41:22 PM   #2
Lencross
Mine wont...I bought it for nothing..wont clear the HEI
Lencross is offline   Reply With Quote
Old 11-05-2006, 07:50:58 PM   #3
Damon
www.ramairbox.com
That's a GOOD dual snokel setup that is non-restrictive (unlike most factory setups which really don't flow all that well). It, likewise, won't clear an HEI but the surround is made of fiberglass so you can easily trim it to fit with a Dremel or similar.
1990 454SS pickup. Original "tow truck motor" 454 upgraded to something a little more "aggressive." Seems pretty stout but the fuel bill is nuts.
78 Malibu. Inherited with only 35K on the odo! Mild 383 with Weiand 142 blower on top. Mid 12s appears to be the best it's gonna do on street rubber. Runs so good I may never drive it again.
"Last remaining QJet tuner on planet Earth!"
Damon is offline   Reply With Quote
Old 11-06-2006, 06:53:06 PM   #4
JerryL
JerryL's Avatar
What about the open element type that came on 73-74 corvettes? Are the housings the same as the Z28? What year did HEI start?
Old 11-06-2006, 07:30:08 PM   #5
Steve's 74
Steve's 74's Avatar
With a little massaging. I believe this is a 74+ corvette bottom and I used a top from a normal V8 15 1/2 air cleaner instead of the higher top. (I picked up both at a swap meet for about $10.) The rear comes factory indented to fit the HEI. I've got a 2" custom diameter K&N filter inside. And I had to notch and seal 2 areas on the underside to clear the Holley float adj screws. It fits under the stock hood. But I don't know if I'm going to continue to use it. It may be a bit restrictive on the air flow.
1974 Sport Coupe original owner.
350 sbc, full roller cam, e-tec 64cc/200cc, tko600, 3.42, x-pype duals, AGR steering, rear discs, electric fans, recessed bumpers.
Steve's 74 is online now   Reply With Quote
