Old 09-27-2006, 07:06:53 AM   #1
hansoni
Big hole in firewall
I cant remember what goes here. In between the hole for the steering column and the main fuse panel, and just above the round hole for the speedo cable, is a 2" or so hole that I just cant seem to figure what goes here. Duh.
hansoni is offline   Reply With Quote
Old 09-27-2006, 08:47:33 AM   #2
ParkerRS
It is for the clutch pedal push rod and seal. On cars with automatic trans. there is a small sheet metal cover with a seal on the back which covers it and is held in place with two screws.
ParkerRS is offline   Reply With Quote
Old 09-27-2006, 10:27:08 PM   #3
spoonLT1355
spoonLT1355's Avatar
/\/\/\/\ what he said /\/\/\/\
Μολὼν λαβέ
Tip of the Day: Be careful of following the masses - because when you remove the "m", who exactly are you following?
Some of the wiring diagrams that I have,
http://community.webshots.com/user/spoonlt1355
Pics of April's Cobolt gauge set-up:
http://www.cardomain.com/id/spoonlt1355
Tilt steering column rebuild:
http://www.cardomain.com/ride/3223935
spoonLT1355 is online now   Reply With Quote
Old 09-27-2006, 10:36:23 PM   #4
rgearhead
LGM, BAAAB
rgearhead's Avatar
I Have A Hole About1 1/4" Just Left Little Lower Than Brake Boster Dont Know Why It Not For 4 Speed Because Car Has Factory 4 Speed 73rs
rgearhead is offline   Reply With Quote
Old 09-27-2006, 10:38:04 PM   #5
rgearhead
LGM, BAAAB
rgearhead's Avatar
Looking At That PicTCURE Hole Is Between BrAKE And Wiper Hole
Old 09-28-2006, 12:24:41 AM   #6
spoonLT1355
This front section came off a 73 4 speed car. It is as-is from the factory.
Maybe some-one added the hole in question for running aftermarket gauges??
Μολὼν λαβέ
