Go Back   NastyZ28.com > Body & Chassis Restoration > Electrical Systems
Old 08-05-2006, 11:03:00 AM   #1
Camaro in OZ
Turn signals not working
I have a 1973 Camaro and the turning lights are not working, I have power to the relay and when I ground the other terminal with a test light the test light globe flashes. From there that wire dissapears into a wiring harness. Help with what and how to test the next part of the system would be a great help, thankyou...................................... .
Camaro in OZ is offline   Reply With Quote
Old 08-05-2006, 07:21:01 PM   #2
Rick76LT
When you flip the turn signal arm, does the bulbs light up or does it not do anything? If they light up, but dont flash, i think its usually the bulbs or the flasher itself. Those are the usaul things i check first and 98% of the time for me, one of those is the problem. other than that im not much help.
Rick76LT is offline   Reply With Quote
Old 08-05-2006, 09:16:11 PM   #3
Camaro in OZ
Thanks for that, The bulbs are ok the hazard lights work properly, I know they are on a diffrent curcuit but all the lights flash when I put the hazards on.
when I flip the turn signal arm no lights come on at all............ò¿ó¬...........
Old 08-06-2006, 11:02:49 AM   #4
curtg21
most likely is the turn signal switch in the column. Check for loose wires before you buy a new one though.
10th St. Hooker Coming soon.
curtg21 is offline   Reply With Quote
