Old 08-03-2006, 12:45:24 AM   #1
yobin67
source for new backing plates?
I'm still looking for new backing plates for 9" x 2" rear brakes. Does anyone know the part number for the GM piece? I've heard they are still available.Any other sources?
pump gas 355,3400lbs,11.31@119.4
100 shot NOS,little less gear,all else the same 10.85@125
http://i553.photobucket.com/albums/j...7/IMG_0129.jpg
http://i553.photobucket.com/albums/j...7/IMG_0125.jpg
yobin67 is offline   Reply With Quote
Old 08-03-2006, 11:55:06 AM   #2
internetautomart
BRAKE DRUM BRAKE BACKING PLATE
DORMAN - AUTOGRADE 720-134 BRAKE BACKING PLATE
Note: rear: 1 pc, w/o wheel cyl *
DORMAN - HELP 13706 BRAKE BACKING PLATE
Note: rear: 2 pc, w/o wheel cyl 92.43
DORMAN - HELP 13707 BRAKE BACKING PLATE
Note: rear: 2 pc, w/wheel cyl 115.85
DORMAN - HELP 13867 BRAKE BACKING PLATE
Note: rear: 1 pc, w/o wheel cyl 36.71
WAGNER F122524 REAR BACKING PLATE
Note: 2 per veh; univ 1-pc, remove axle for instl'n; 9 1/2" brks; rpl lt & rt side by punching out park cable plug *
Note: 2 per veh; univ 1-pc, remove axle for instl'n; w/9-1/2" brks; rpl lt & rt side by punching out park cable plug *
WAGNER F128621 REAR BACKING PLATE
Note: 2 per veh; univ 2-pc, eliminates need to pull axle; 9 1/2" brks; rpl lt & rt side by punching out park cable plug 83.52
Note: 2 per veh; univ 2-pc, eliminates need to pull axle; w/9-1/2" brks; rpl lt & rt side by punching out park cable plug
www.classiccarsprings.com <- Leaf springs and Coil Springs.
Eventually I'll redo the Chassis parts
internetautomart is offline   Reply With Quote
Old 08-03-2006, 12:12:08 PM   #3
br80z
I know that they are available through Advance Auto Parts (yes I work there part time)
http://www.partsamerica.com/ProductL...+Backing+Plate
but most parts stores should be able to get them
Motormite Part Numbers
1 piece backing plate 13867
2 piece backing plate 13706
Brian
1998 Camaro - Daily Driver
1980 Z28 - Much assembly required!
br80z is offline   Reply With Quote
