Old 07-30-2006, 08:49:23 AM   #1
andymiller
andymiller's Avatar
Spark Plug gap for MSD box
What spark plug gaps are you guys using with MSD boxes? I have a mild built 355 and running a MSD 6a box. Basically a stock type HEI dist. 9.6 cr
andymiller is offline   Reply With Quote
Old 07-30-2006, 09:20:14 AM   #2
CorkyE
CorkyE's Avatar
I've been up and down the range of gaps and found .040 works best for me. Really, you'll just have to play around, but .040 will be a good starting point.
Corky
79 Z28 bought new, honeymoon ride same year, still have same wife, same car.
CorkyE is online now   Reply With Quote
Old 07-30-2006, 09:54:47 AM   #3
Damon
.045 is about where I run them. You can probably go wider but I never do on a street motor- the wider the gap the more strain it puts on the whole secondary side of the ignition. My brother runs them at .065 but he always seems to be replacing coils and coil wires a lot more than me. I usually go years without wearing out ignition components.
1990 454SS pickup. Sold, but I think she found herself a good home.
78 Malibu. Inherited with only 35K on the odo! Mild 383 with Weiand 142 blower on top. Mid-high 12s on street rubber, bottom 12s on DRs with the trans left to shift for itself. Runs so good I may never drive it again.
"Last remaining QJet tuner on planet Earth!"
Damon is offline   Reply With Quote
Old 07-30-2006, 08:48:08 PM   #4
Joekool
With 9.6 to 1 c/r .040 to .045 should be fine, if your compression where to increase then you would need to lower the plug gap. I have around 10.25 to 1 and .035 seems to work the best for my engine.
Joekool is offline   Reply With Quote
Old 07-31-2006, 06:02:35 AM   #5
andymiller
andymiller's Avatar
I've always heard you wanted tp run a large gap with these things to make a big hot spark.
Old 07-31-2006, 08:19:40 AM   #6
Marv D
Marv D's Avatar
The larger the spark kernel the better, but when you start running more and more compression it is harder for the electricity to jump the gap, so you have to give up a large spark for reliability of the plug firing every time. At 14:1 you'll typically see the racing plugs gapped at around .028 -.32. But like Damon suggested, MSD suggests a starting point around .035-.045 for normal street compressions.
Marv D is offline   Reply With Quote
Old 07-31-2006, 12:39:46 PM   #7
blue 79 Z28
i agree. for n/a i run .035 on mine, and for nitrous i run .030 thats with a digital 6 ignition, and just over 11:1 on the motor, never had a plug issue or ignition hiccup.
blue 79 camaro Z/28
old time 355 sbc:
- 520/697hp 450/650 lbft - 150 shot
- 10.13@134.5mph 1.45 60ft 3650lbs
new 468 bbc:
- 622/880hp 570/865 lbft - 200 shot
- new times soon
95 camaro 383 LT1 - just another 500hp n/a street car
blue 79 Z28 is offline   Reply With Quote
