Old 07-16-2006, 11:04:01 PM   #1
Torque_2_spec
tires rims
i am racing in high speed autocross with midwestern council of sports car clubs. 71 camaro. pic is on my yahoo profile. i am losing to a 91 pontiac formula and a 96 impala. they both have 17 in. wheels with 275/40 tires, 140 treadwear rating. i want thier tires and wheels. anyone here ever update thier old camaro with 17's? any suggestions please email me. thanks.
currently running gm steel rally rims. 15x7 front and 15x8 rear with dunlop 8000 225/50 front and 245/50 rear.
Torque_2_spec is offline   Reply With Quote
Old 07-16-2006, 11:56:31 PM   #2
72CamaroSS
72CamaroSS's Avatar
This should help you.
http://www.nastyz28.com/forum/showthread.php?t=47101
Welcome to the board.
There is always beer in the fridge and work to be done, stop on by..............JOHN
1972 RS/SS
DRIVE BY
SPIN TECHs idling
AutoX run
72CamaroSS is offline   Reply With Quote
Old 07-17-2006, 12:02:22 AM   #3
1981paul
Moderator
1981paul's Avatar
What class are you racing in?
If you are in C Prepared, you want to run a 16" wheel, prefferably 12" wide, but 10" will work. You'll want to run a byass-ply autocross slick like the Hoosier.
If you are in another class, like Street Mod you'll want a DOT approved slick. I'm running the Kuhmo 710s on my Street Mod car.
If you are running in a street tire class, you'll want the Falken Azenis RT615. This is a very compitent street tire with a tread raiting of 140. I raced on these last year and they are pretty much the fastest street tire you can get for this sort of thing. You just have to spray them down between runs on hot days.
I also daily drove on them, so you could use it as a multi-purpose tire.
Paul P.
1981 Camaro C-Prepared Autocross Project
Help Fight Lung Cancer
The John and Amy Mewhiney Cancer Foundation.
Maryland's Premiere Autocross Team
Team Zip-Tie
1981paul is offline   Reply With Quote
Old 07-17-2006, 10:26:35 AM   #4
67lemanster
LGM, Team Flatback
67lemanster's Avatar
your kidding right? of course not. we always leave our camaros with stock wheels and 70 technology tires. LOL
pic below. this is about the cheapest way to do it, i have found.
17x9 steel rears 60.00 5" bs
17x8 steel fronts 55.00 4.5" bs
kuhmo tires 285/40/17's rear and 245/45/17's front. i am switching to 255/40/17's in the front soon. should have no real fitment issuese
This instigator isnt going anywhere
Hey there Curly, IS YOUR MAMA HOME?
http://smokefreequitmeter.com/index....nner/52022.png
When you are down in the dumps and think you have realproblems, just remember:
SOMEWHERE IN THIS WORLD,
THERE IS A POOR BASTARD NAMED MR. PELOSI.....
http://community.webshots.com/user/scamaro69
67lemanster is offline   Reply With Quote
Old 07-18-2006, 01:10:02 AM   #5
Torque_2_spec
hey all. what a great response. thanks.
Paul, i am running in super street. I can`t put it in c class because i put a full frame in it and made my own shock mounts. with all the points i get for mods i am over the limit. in scca i gave handicaps to corvettes and wrx`s. i am compettitive in super street. if losing by tenths can be called that. also, the tire i want should have phony tread. just there for looks. or at least huge blocks of tread.
67lemanster nice camaro, and john thanks for the beer.
of course in a perfect world i`d have 17x10 in wide rims all the way around. all 4 tires the same size. i don`t like bustin tires down to rotate them. and i want more of a trans-am racing look to the car. i may flare the wells.
Old 07-18-2006, 01:21:00 AM   #6
SHANE 73Z
This thread is worthless..........without pics.
Welcome to the site. With the right ride height/wheel backspacing you might be able to run the same size all around.
Shane
73z - 406sbc 430hp/475tq - TKO 600 - Torsen T2/3.73 - 12" Discs - 16" Minilite replicas - Homebrewed suspension - Mucho chassis bracing - Lots of fiberglass - Not much interior
Maybe it will see an Auto-X someday
SHANE 73Z is online now   Reply With Quote
Old 07-18-2006, 10:33:27 PM   #7
1981paul
Moderator
1981paul's Avatar
You want the widest Kuhmo V710 you can fit under the stock lips. I would suggest a 15" rim, just for cost, but you can upgrade to a 17 and still have fun.
Technically, you're not legal for SS, so changing out the rims from a size other than stock is the least of your worries.
You should be in a Mod class. C-Mod maybe?
Paul P.
Team Zip-Tie
Old 07-19-2006, 12:13:02 AM   #8
Torque_2_spec
3 Super Street Category
This category provides a natural competition outlet for auto enthusiasts using affordable automobiles equipped with
common suspension, engine, and appearance modifications which are fully legal and compatible for street use
anywhere in the country. This class is designed for the enthusiast that wants to modify their engine swap or O.E.
outfitted automobile in the guidelines listed below. Class/category designation is SS.
3.1 Authorized Modifications
3.1.1 All Restricted Street modifications are allowed.
3.1.2 All Street Modified modifications are allowed.
3.1.3 Bumper braces/supports may be removed or replace by a lighter replacement. If using a lighter
replacement it must retain factory mounting location.
3.2 Tires
3.2.1 Tires shall have a minimum tread wear rating of 140.
3.3 Brakes
3.3.1 Conversion brake kits are allowed as long as they retain original mounting points (i.e., Aem, Baer, and
Wilwood).
3.4 Engine and Drivetrain
3.4.1 The engine management system parameters and operations may be modified only by the methods listed
below. These allowances also apply to forced induction cars, except that no changes to standard boost
levels, intercoolers, or boost controls are permitted.
3.4.1.1 Reprogrammed ECU may be used in the standard housing.
3.4.1.2 Electronic components may be installed inline between an engine's sensors and ECU. These
components may alter the signal coming from the sensor in order to affect the ECU's operation of
the engine management system. Example: Fuel controllers that modify the signal coming from an
airflow sensor.
3.4.1.3 Fuel pressure regulators may be replaced.
3.4.1.4 VTEC controllers and other devices may be used which alter the timing of factory standard electronic
variable valve timing systems.
3.4.1.5 Boost controllers are not allowed (must go to Unlimited Street).
3.4.2 Allowed: Driveline/Engine modifications:
3.4.2.1 Camshaft replacement.
3.4.2.2 Headers (emission-legal).
MCSCC 2006 GCR Time Attack / Autocross Page 37
3.4.2.3 Accessory belt under-drive pulleys.
3.4.2.4 Aluminum/lightened flywheels.
3.4.2.5 Racing clutches.
3.4.2.6 Stock turbos and stock intercoolers must be retained. Blow-off valves may be changed/modified
3.4.2.7 Maximum engine displacement:
3.4.2.7.1 Forced induction
3.0L (OHC engines )
4.0L ( pushrod engines)
3.4.2.7.2 Naturally aspirated
5.7L
3.4.2.7.3 Rotary engines
1.5 (all)
sounds like i fit right in. no points are assessed. heads up racing. i put in a rollbar and harnesses for saftey. good to go. next class up is big blocks. i am where i need to be.
car at milwaukee mile http://us.f2.yahoofs.com/users/44865...xAbvEBEGeozRAY[IMG][IMG]
6 scca first place trophys in solo2 http://f3.yahoofs.com/users/41e05d4f...4ObvEB1xeMwi6l
i need to post some pics of the back of my car. i removed the reverse lights and ran the exhaust out the holes. 2 1/2 in. stainless tips. people freak out on it. it looks cool.
Old 07-19-2006, 09:29:12 AM   #9
67lemanster
LGM, Team Flatback
linkies no workie cool car in your profile page though. looks like you have brake ducting to through the front spoiler. what did you use at the caliper/rotor. or did you just tie off a piece of ducting to funnel air to your caliper/rotor
Old 07-19-2006, 09:39:51 PM   #10
1981paul
Moderator
1981paul's Avatar
Sorry about being off on the class... I guess I was having a brain fart... I'd love to see some pictures...
Paul P.
Team Zip-Tie
Old 07-19-2006, 11:09:25 PM   #11
internetautomart
My .02
Find the lightest 15x10" wheel and run that.
the weight saved over a 17" wheel will greatly affect the handling for the better.
of course good luck finding a racing tire wider than a 225/45 in a 15"
www.classiccarsprings.com <- Leaf springs and Coil Springs.
Eventually I'll redo the Chassis parts
internetautomart is offline   Reply With Quote
Old 07-20-2006, 12:57:05 AM   #12
Torque_2_spec
yeah the 15 inch racing tires are for fwd cars. they don`t have the load range for my old boat.
and wow, the links work for me, that sucks. i painted it and did all the body work. i sewed a 19 piece carpet. i made door panels from scratch. my wife made the headliner. took me forever to find a pic for my profile smaller than 60.5kb.
and i had the duct attatched to the dust shield for the front rotor, but on the test drive i ripped them up. now they just point at the caliper til further development. it don`t matter for timed runs cause one hot lap won`t overheat the brakes. it`s 3 laps of practice that heats em up. i do have a few pics on the internet that other people took. i`ll try them.
blackhawk farms raceway
http://mcscc.org/Gallery/albums/album06/771_G.thumb.jpg
milwauke mile jun 10th
http://mcscc.org/Gallery/albums/album07/771_G.thumb.jpg
autobahn country club
http://mcscc.org/Gallery/albums/TA-A...71_G.thumb.jpg
mil mile may 20th
Old 07-20-2006, 09:01:15 AM   #13
internetautomart
no matter what you want to run the smallest rim you can.
have you thought about getting stock car slicks?
Old 07-20-2006, 10:36:03 PM   #14
Torque_2_spec
no, the smallest rim won`t help anything. driving the car i know my biggest limitation is grip. i want a 275/40 series tire on my car at all 4 corners. the last 4 yrs of racing tells me i need a tire that don`t roll on it`s sidewall. 4 sets of front tires, none have made it over a thousand miles. all the outside edges are gone. center tread brand new. i run with two degrees of negative camber. i run 55 psi on the track. any lower psi and it starts to wear where there ain`t no tread.
gary forman- my competition- has 275/40/17 on his 96 impala. runs them at 40 psi. and they don`t roll onto the sidewall. and the 91pontiac formula and the 02 camaro run simular tires- same rim size-17. i run a 225/50/15 dunlop 8000 up front and it begs me not to drive the car. it was a nitto before that and a goodrich ta then a eagle gt.all these tires suck. and if i gotta cut the fender to the hood i am gonna have tires hookn under this b#@ch next year.
Old 07-20-2006, 11:46:30 PM   #15
1981paul
Moderator
1981paul's Avatar
If you have to stick with the 140 treadwear raiting, I have to insist you go with the Falken Azenis RT615.
There are a lot of sizes available, and they have a very wide footprint. Get some heat in them, and they stick like glue. They are the best street tire short of going ot a full DOT legal slick like the v710. Falken also improved the design over the old 215s, making them more tollerant and forgiving of heat generated by lager cars. They have very stiff sidewalls and are happy with -2* of camber.
YOU WILL NOT BE DISAPPOINTED.
Prices from tires.com
Size Price
205/40R-16 83W XL B $94.00
205/40R-17 84W XL B $105.00
205/50R-15 89W XL B $87.00
215/40R-17 87W XL B $112.00
215/45R-16 86W XL OW $107.00
225/40R-18 92W XL B $141.00
225/45R-17 94W XL B $122.00
225/45R-18 91W BLK $171.00
225/50R-16 92W XL B $118.00
235/40R-17 90W XL OW $134.00
235/40R-18 95W XL B $149.00
245/40R-18 97W XL B $162.00
245/45R-17 99W XL B $124.00
255/40R-17 94W BLK $137.00
255/40R-18 95W BLK $166.00
255/45R-18 99W XL OW $212.00
265/35R-18 93W OWL $234.00
275/35R-18 95W BLK $225.00
275/40R-17 98W BLK $156.00
295/40R18 103W XL OW $249.00
315/30R-18 98W XL OW $316.00
Paul P.
Team Zip-Tie
